mounting 1/8 buggy calibers??
little help here, getting ready to mount some calibers and if i go by the arrow on the tire i will have 2 tires with differnt tread going wrong way? unless i put all 4 tires on one side of the buggy...LOL. the tread on these down the center is directional, do i need to just put 2 tires on backwards according to arrows on tires? thanks guys.
thats what i did
now looking wonder if there is a frnt set and rear set
http://prolineracing.com/tires/calib...gy-rear-tires/ http://prolineracing.com/tires/calib...y-front-tires/ |
the package says for front or rear wheels, so im assuming you just turn as needed, arrows on tires will be wrong on 2 of them, kinda stupid:weird:, just wanted to make sure before i throw the glue at them:nod:
tires
. As long as the tread is the same on each side ;) Now i screwed up lol yes mike arrows facing forward on all 4.Just make sure the v pattern is facing the same direction both sides
Originally Posted by teamlosi906
(Post 8357249)
2 arrows forward 2 backwards . As long as the tread is the same on each side ;)
Arrows going forward on all 4.
Originally Posted by rpm1968
(Post 8357281)
Originally Posted by inferno13
(Post 8357293)
wrong............but thanks for the reply:) teamlosi906 is right, i also looked it up to make sure.
i have the pattern on the tires like this.....>>>>....going forward on all tires, but 2 of the arrows on the wheels are backwards, if i go by the arrows on tires, either fornt or rear pattern will be oppisite, or left to right side.
Originally Posted by newuserlosi8t
(Post 8357200)
(Post 8357281)
(Post 8357324)
all 4 tire arrows go the same direction giving the same amount of traction... if you dont the car will have more grip on 1 side of the car over the others... mount all the same way.. what i have done is if you have to much traction flip both rear wheels the opposite direction.. you then dont have as much forward bite but the fronts will have the same... this is a tuning aid.. |
Originally Posted by J.Whiting
(Post 8357372)
those are for 1/10th 4wheeler class
yes yes yes what happens if you have 2 tires one direction and 2 the other ( saying left to right not front to back) you WILL get a pull or push...... all 4 tire arrows go the same direction giving the same amount of traction... if you dont the car will have more grip on 1 side of the car over the others... mount all the same way.. what i have done is if you have to much traction flip both rear wheels the opposite direction.. you then dont have as much forward bite but the fronts will have the same... this is a tuning aid.. |
(Post 8357408)
well i dint glue them yet. if i put the arrow on the tire going forward on all tires, 2 tires have the tread going in oppisite direction, so put 2 on the back and 2 on the front with oppisite tread pattern?
(Post 8357408)
2 Attachment(s)
the top tires are for the right side. The bottom is for the left side :lol: I just cant figure out how to make the pics larger. lol
