Old 12-13-2010, 05:08 PM   #1
mickeymouse93's Avatar
Trader Rating: 18 (100%+)
Default nitro help
Hey guys I just picked up a used hyper 2.0 roller. I put everything in and broke the motor in. Well I have about 16. Tanks through it and started to lean her out. About 5 minutes into a run is would scream at take off as if the shoes went out. But I have the metal shoes in there
is it possible the shoes went out already? Or did I lean the bottom out too much? Thanks guys!
Factory Team Associated SC10
Pro-Line
Novak
mickeymouse93 is offline   Reply With Quote
Old 12-13-2010, 05:30 PM   #2
koopesv's Avatar
Trader Rating: 18 (95%+)
i think it could be the clutch spring one might have broke. or you could be lean on the bottom
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 12-13-2010, 05:55 PM   #3
Thanks for your input!
Pro-Line
Novak
Old 12-13-2010, 06:04 PM   #4
Checked the springs and they were fine.
Pro-Line
Novak
Old 12-13-2010, 06:13 PM   #5
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
Be careful on tunning. I always say tune in hour incraments. Look at ur needle as a clock and tune at hour a time.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 12-13-2010, 06:19 PM   #6
robbieg's Avatar
Trader Rating: 26 (100%+)
make sure the flywheel is tight. may be spinning on the crank shaft if the flywheel nut is not good and tight. also check to see if you have some oily residue inside the clutch bell. if you replaced the cb bearings some bearings have alot of grease applied and when they heat up it ends up on the inside of the cb and shoes making it slip excessively.
robbieg is offline   Reply With Quote
Old 12-13-2010, 06:26 PM   #7
I did notice some oil. I will clean that out. Thanks so much guys.
Pro-Line
Novak
looking for some nitro help vypr2002 Nitro Off-Road 20 07-26-2010 09:08 PM
rc nitro help mrblonde Georgia Racing 10 02-06-2010 08:12 AM
Electric Guy goes Nitro...help! eziduzit Electric Off-Road 13 05-18-2007 08:40 PM
Frustrated with my first nitro, help! bcmorrison Rookie Zone 6 02-21-2005 10:49 PM
