Old 12-12-2010, 08:56 PM   #1
carcnut's Avatar
Default Pull Start vs Starter Box
Hello All,
I got my first and it's used Nitro truggy a XT2, and it has a XTM 457 engine in it. It came with a starter box and to me it seems like a big pain in the butt to use and start it with. It seems like a pull start would be a lot easier and I wouldn't have to lug around the starter box and worry about recharging it. So are the pull starts really that bad or problematic? I am considering buying the pull start assembly for $30 unless its a huge mistake? All comments are appreciated.
D.
__________________________
Bashn' XTM XT2 & X-Cellerator || MERV || Jato 2.5
Coming out or R/C retirement....$lowly!
-=David
carcnut is offline   Reply With Quote
Old 12-12-2010, 09:10 PM   #2
pull starts will break on you regularly. get a roto start. i think is the most convenient way to start ur car.
sheldon637 is offline   Reply With Quote
Old 12-12-2010, 10:01 PM   #3
petevette's Avatar
Send a message via Yahoo to petevette
It shouldn't be a lot of trouble to start it with a box. Are you alignment pegs correct? If they are, it should be easy to start.
petevette is offline   Reply With Quote
Old 12-12-2010, 11:10 PM   #4
shanty140's Avatar
If you can tune a motor somewhat ok, and are bashing and just having fun. The pullstart is the way to go. Also if you don't pull the cord like your trying to start a lawn mower, the pullstart should last a long time. Rotostarts are generally easier for people who may have a little trouble tuning a motor. But it's just another thing you have to haul around and charge. And is a lot harder on one way bearing then there pull start counterparts.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 12-13-2010, 01:02 PM   #5
Started boxes are preferred by all racers. Pull starts and rotostart creates tuning nightmares.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 12-13-2010, 01:54 PM   #6
jwm2's Avatar
Not only are pullstarts rough on your arm & hands, they are easily broken and will need to be replaced often. Not to mention if your engine is having a bad day and doesn't want to fire on the first couple pulls. Its so much easier to use a starter box. Would you rather start your lawn mower will a recoil or electric ignition? Nuff said.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 12-13-2010, 01:57 PM   #7
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Really?? Stick with the starter box dude.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 12-13-2010, 03:59 PM   #8
scwrod's Avatar
Just take the time to set up the starter box. Take the nitro motor off to get the bump wheel perfectly lined up and centered with the flywheel cutout.
hbracing.com tritonrc.com raceaka.com
scwrod is offline   Reply With Quote
Old 12-13-2010, 04:11 PM   #9
Pullstarts are fine but will not last long. Especially if this is your first nitro truck. You'll spend a lot of time pulling the little rope!
You better keep your starter box. Make sure pegs are well aligned so the flywheels hits the rubber wheel. You can remove your engine to make adjustment easier.
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 12-13-2010, 04:13 PM   #10
Fortega95's Avatar
Default STICK WITH THE STARTER BOX
the starter box is way more easyer then trying to start a motor with a pull start. Plus dont need a one way bearing.
Fortega95 is offline   Reply With Quote
Old 12-14-2010, 08:35 AM   #11
Originally Posted by carcnut View Post
Hello All,
D.
We have 2 rtr truggies and converted them both with pull-start eliminators to use on starter boxes. The starter box is the way to go.
kings & reds
grouseridge is offline   Reply With Quote
Roto Start VS. Bump Start rsmith569 Nitro Off-Road 11 02-21-2009 02:39 AM
DM-one or GT2... + starter box question - want your input! ScudMan Nitro On-Road 48 11-05-2008 07:54 PM
Pull Start vs Electric start? diablo05 Singapore R/C Racers 6 01-27-2007 05:12 PM
Pull start VS. Starter Box Supernitro17 Nitro On-Road 9 04-10-2003 05:00 PM
