Old 12-09-2010, 07:03 PM   #1
Fortega95's Avatar
Default LOSI 8IGHT 2.0 RTR reviews
Im getting ready to get the losi 8 2.0 rtr. Let me know what you think of it and if it will handel the same way as the race roller thanks
Fortega95 is offline   Reply With Quote
Old 12-09-2010, 09:26 PM   #2
jwm2's Avatar
Can't go wrong with the rtr. It'll get you as far as your skill will take you. You'll of course want new servos pretty quickly, but otherwise its rock solid and performs well. I don't really notice much of a difference (handling wise) between them (race roller vs rtr) to be honest.
You'll want a quick 100oz servo <.15 transit time for the throttle and brake, and a 150+ oz servo for the steering.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 12-09-2010, 09:52 PM   #3
Sein's Avatar
+1 I don't have both but I do have the rtr and, when I drive real smooth, I can run just as fast as all the fast guys at my track. I'm the only one with an rtr though. Like jwm2 said, it's as good as the driver who is driving it.
I upgraded the servos and put a turbo head on the 454 with an re11 pipe and it is golden. The servos, no matter what, you will have to upgrade but everything else you don't really need.
The 454 has a very strong pinch from the factory and it takes, at the very least, 1.5 gallons to fully break in. Mind did not "drop it's nuts" till about 3 gallons in. I am starting my 5th gallon right now and the piston will still push the sleeve out of the block at TDC, with cooling head and head button off.
You will want to change the clutch once you start racing. It has a real high stall (engages late). You'll want to go with a softer setup. That 454 has a lot of torque and you will get better traction with the softer (earlier) clutch engagement.
Here is a vid of mine on the track:
http://www.youtube.com/watch?v=Ie8v242zc2Y
Ronnie Senters/Glory2God Racing
D8T-Alpha A352/D812-Alpha A852
Team Hotbodies Hawaii
Sein is offline   Reply With Quote
Old 12-10-2010, 05:50 AM   #4
Suspended
Trader Rating: 202 (96%+)
your 2.0 buggy came with a 454?, mine came with a 350.
i have the rtr buggy and ran it last year with no issues at all, i did change out the servos the day i received it from UPS. i went with xp1015 servos. the rtr only comes with 2 clutch shoes installed, will have to add two more, (i thought that was odd). but over all very happy with it, this year i will be running a GO GX7R in it. good luck!
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 12-10-2010, 07:41 AM   #5
jwm2's Avatar
He's reffering to a 8-t 2.0 which is the only vehicle to come with a 454. The 1.0 buggy and truggy both came with the 427 which was too big for the buggy and too small for the truggy.
Old 12-10-2010, 07:51 AM   #6
Suspended
ah, gotchya!
Old 12-10-2010, 09:02 AM   #7
Sein's Avatar
ah, gotchya!
Yea my bad. Wasn't paying attention to the thread title.
Old 12-10-2010, 09:04 AM   #8
Suspended
LOL... i was going to say, cant imagine a 454 in a buggy! thing would be CRAZY!! LOL
Old 12-10-2010, 10:20 AM   #9
jwm2's Avatar
It wouldn't be as powerful as the 5 port you had in yours just a short time ago. The 454 isn't a destination mill, its a starter engine. Thats why you don't see them in anything but the rtr. If they were great racing motors you'd see alot of folks putting them into the race rollers instead of the $300-500 motors going into them now.
Old 12-10-2010, 10:23 AM   #10
Suspended
TRUE!!!!
Old 12-11-2010, 06:39 AM   #11
sluggo_sx8's Avatar
If the 454 wasn't such a pig on fuel it would a awesome motor. My sons was faster then any .21 on the track at any time. The prob was it had way to much power and was way to hard on fuel and to hard to control. Even with a soft clutch setup and a different carb (7.5mm insert) I could only get 9min and that is being very soft on the throttle. Soon as I put a .21 in his truggy his driving improved huge cause the power was way more controlable. Just remember the stock bearings are junk and should be changed before or at 2 gallons.
Over all the losi rtr's are awesome to get you started and if you are only club racing will do everything you need them to do. The servos are junk and will fail. If you are learning and crash alot you will break shock caps so you may want to upgrade to the metal ones. Drive the crap out of it and replace stuff as it wears and breaks with roller parts.
sluggo_sx8 is offline   Reply With Quote
Old 12-11-2010, 07:17 AM   #12
lanmine657's Avatar
the losi rtr is not your average rtr car, after a few upgrades you can have a car that will be as good if not identical to a race roller. The 350 is great motor and will have plenty of life(12-14gallons+) if u take care of it and has plenty of power to keep up with those high end motors. the name of the game is consistancy not speed or power. I have an upgraded rtr and by no means am i at a disadvantage against a race roller. Unless you are racing adam drake every weekend the rtr is the way to go. Upgrade the servos to hitech 7955, EU shock caps with dampers, adjustible hinge pin braces and set the car up as per adam drake set up sheet on the losi website. Once you have done those set ups the only reason that car cant win will be the driver!!
Buggy on the Brain
MotoAdventure Kawasaki
LOSI
Riva-Sinister Skis-Jetworks-Jet Pilot
Coorslight
lanmine657 is offline   Reply With Quote
Old 12-17-2010, 08:10 AM   #13
madweazl's Avatar
I have the buggy and truggy and have been very happy with both. I did the turbo head conversion and run a GRP (2056 I believe) on the 350 with the RE11 on the 454. The front bearing on the 350 has started leak (probably has 3-4 gallons on it) but it still runs great (I ran the GRP for a while but went back to the 350). The 454 is very strong with the turbo head and RE11. I can almost get 10 mins out of the 350 with a good tune but havent been able to pull that with the 454 (about a minute less with it; blocks removed from tanks in both).
Out of the box I went with LiPo rx pack and Hitec servos (love them!). I never broke a shock cap but did replace all 4 on the buggy as they started to wear at the eye. Have the aluminum caps for the truggy but it doesnt have much run time so the stock units are still in good shape (just been to lazy to install them).
I dont think I've broken a single part on either. I remember bending a shock tower on the buggy (replaced with Race Roller parts). Oh, I did have a shock standoff break on the truggy before it even hit the track (dropped it on the pit table and it broke); I'm guessing it was over tightened at the manufacturer. Been very happy with both of them but I'm in the market for something new to play with now.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 12-20-2010, 07:33 AM   #14
gregsbox's Avatar
Check it out here
[YOKOMO] [XRAY] [SANWA] [TEKIN] [ALIGN] [JR]
www.thisisrc.com
www.thisisbluerain.com
gregsbox is offline   Reply With Quote
Need advise - New to Nitro Buggies Filthyfil Nitro Off-Road 22 08-28-2010 11:15 AM
Heat Issues with my Losi 8ight 2.0E LosiRox Electric Off-Road 22 09-22-2009 08:39 PM
Is 350 still a good deal for a losi 8ight? Tate72 Nitro Off-Road 19 09-02-2009 07:32 PM
8ight starter box Jonro Nitro Off-Road 69 03-19-2009 06:44 AM
