Old 12-05-2010, 06:10 PM   #1
Default 1/8 Buggy Brake Help
On buggies with independent front and rear brakes, what setup is typically used for racing? Should the front brake have more power than the rear like in a real car, or should braking power be about equal?
Zio667 is offline   Reply With Quote
Old 12-05-2010, 07:30 PM   #2
I set 60% rear and 40% front. It helps to rotate the car when hitting the brakes.
Too much front brake will lock the wheels and you can steer when the front wheels are locked.
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 12-05-2010, 07:37 PM   #3
hustler777's Avatar
Send a message via MSN to hustler777 Send a message via Yahoo to hustler777
for my personal setup, i prefer having it @60/40 front to rear with a little drag brake to the rear to help rotate the car a bit....but this is what fits my driving style the best....i also use the anti-lock brake option on my 3pk...
Sometimes you gotta go back to come back...
hustler777 is offline   Reply With Quote
Old 12-05-2010, 11:07 PM   #4
Setting the brakes is almost one of the most important settings on the car & finding your datum point is just the same so they are always the same when you change or alter them.
Setting to F60% R40% is what most say they do but its all normally done by feel on the track as to set on the bench is impossible.
The normal simple test is find a grippy surface or use the track you are to race on. Turn on electrics apply brakes & push car by the wing, all wheels should be locked. Now gradually release the brakes on the tx while pushing the car & note both front & rear should release at roughly the same point.
You can lift the rear & push forward then the front & backward to see if friction of break feels to be the same.
Now when you hit the track under power & apply the breaks weight transfer causes the bias all talk about & the feel fo F60 R40%. If you have to much brake remove it from the TX by servo movement. If the car brakes away at the rear reduce bias, if you want it to brake away more increse rear bias
Bren Ralls is offline   Reply With Quote
Old 12-06-2010, 04:00 AM   #5
Have a look a this http://www.youtube.com/watch?v=P6WHGXq5nfA
It is well explained by Drake
Old 12-06-2010, 04:29 PM   #6
Stubbs's Avatar
Trader Rating: 57 (100%+)
Now this is a good explanation on how to set brake bias....
One question though, in the Drake video, he says that it's 60R / 40F, which is backwards from what's been said here. I'm assuming it's more about the particular type of car, and the person's driving style. Is that a reasonable assumption?
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 12-06-2010, 06:44 PM   #7
I think it is a matter of preference
Old 12-06-2010, 06:54 PM   #8
bboard's Avatar
Start @ 50/50 and adjust to your preference and to the track. If the car pushes to much on brakes adjust with more to rear, if the car overly rotates then take some out of the rear. I prefer to run a little more rear brake to get the car to turn better.
Hotbodies D8-Werks B6/2057-Byrons-Orion LiFe-HiTec Servos-Airtronics M11 2.4
bboard is offline   Reply With Quote
Old 12-06-2010, 07:54 PM   #9
Stubbs's Avatar
That's what I've been doing....just making sure I wasn't off in left field or something.
Good tip on how to get the front and rear matched though. It seems like it would be a bit more precise than turning the tires by hand, unless you do it very often, or have really sensitive hands.
Old 12-07-2010, 07:29 AM   #10
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
I did a vid a little bit ago, and although it's on the RC8, it visualy shows on the car how to mechanically setup brakes properly. Same principals would apply to other cars for the most part. Bias is at the end, but setting up the linkage is at the beginning. Here is the brake section.
There are other sections dicussing getting other parts of the car built correctly, Feel free to give feedback.
http://www.photoshop.com/users/jason...bea04359c56637
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 12-08-2010, 11:59 AM   #11
rangerjkb's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to rangerjkb
+1 on 60R/40F
Jason Burks
Psycho Cells Racing~Hal's Hobby Warehouse~Murfdogg Products~Avid RC
rangerjkb is offline   Reply With Quote
Old 12-08-2010, 12:46 PM   #12
Really nice video, well explained
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11249 07-23-2017 01:50 PM
Tamiya TRF 801X 1/8 Buggy! bola Nitro Off-Road 2517 02-13-2017 09:11 PM
Z-Car 1/8 Buggy E-conversion GSMnow Electric Off-Road 96 12-14-2010 04:32 PM
1/8 buggy diff preference help nelson6500 Electric Off-Road 10 12-29-2009 09:47 AM
