Old 12-19-2010, 06:18 PM   #61
Trader Rating: 25 (100%+)
Originally Posted by pitpop View Post
I can't recall if the SE disk is slotted? You want the smooth ones, no slots. They are more consistent and just work better... I made a decision early on to run steel in Pattaya just because the track was really hard on the brakes. SO much heat and abuse, the risk is when the outdrive slips in the brake disk and turns the slotted hole into a round hole.
Yes, the ones in the SE are non-slotted solid steel, I havent ran the buggy yet i'm just finishing the build but i decided to use a lighter disk brake for less rotating mass but if the solid steel are good i'll go with those.
Thanks,
arm2storm is offline   Reply With Quote
Old 12-20-2010, 03:37 PM   #62
pitpop's Avatar
Thanks,
I totally hear you on the weight thing, it's always better to spin plastic than steel. Honestly though, that small amount of weight is so close to the centerline of the drivetrain, I don't think you will notice it. If you were to calculate the equal impact of weight on the tires, it would probably equal a few nobs on the AKA Enduro, or maybe 3 minutes run time of wear. If you use the steel disks, you also gain the advantage of the expensive phenolic semi metallic brake pads, which provide braking even when wet or splashed with fuel. The fiber type won't.
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 12-21-2010, 06:24 AM   #63
Thanks pitpop, for all the great advice!!
Old 12-22-2010, 09:27 AM   #64
pitpop's Avatar
my pleasure I like chatting with you guys about the cars
Old 12-22-2010, 09:35 AM   #65
Trader Rating: 30 (100%+)
i am currently running the fiber disks and at my last race toys 4 tots at barona in the main my brakes faded 2 laps in not sure why unless at start of race the discs were splashed anyway i will have to go to the smooth disks with pads if this will provide no loss of brakes cost me good finish was fiddling with on the fly brake adjustments half the race
jewn_beef is offline   Reply With Quote
Old 12-25-2010, 04:09 PM   #66
pitpop's Avatar
making radio adjustments during your race can definitely be a distraction
Old 01-03-2011, 07:13 AM   #67
major3d's Avatar
So what is the difference between the SE, TKI and TKI2? Sounds like just some hopup parts. Thanks
major3d is offline   Reply With Quote
Old 01-03-2011, 08:13 AM   #68
Matthijs's Avatar
http://www.kyosho.com/eng/fun/specia...al_data02.html
Exotek F1R3 // Tamiya TRF101
Matthijs is offline   Reply With Quote
