Old 12-03-2010, 07:53 AM   #1
Default losi 8t 2.0 front drive shaft binding
So I rebuilt the whole drive train(new cvd's, dogdones, couplers, everything) and the only issue i see is that the front(center) drive shaft is binding alittle bit at the pinion coupler. Should i take it out and see if i did something wrong or is this normal until the cvd "wears in". Thanks.
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 12-03-2010, 08:27 AM   #2
l3asher's Avatar
Should be fine after a couple runs, just needs to break in. You racing in Watson this weekend?
l3asher is offline   Reply With Quote
Old 12-03-2010, 08:58 AM   #3
Yup looking forward to it.
Byrons 30%
Spektrum
Old 12-03-2010, 05:15 PM   #4
Mikey-B's Avatar
yeah..just run it, itll wear in
Barnstormers racing-DirtCheaprc-Alava Graphics
CarTune Network
Mikey-B is offline   Reply With Quote
Old 12-04-2010, 06:57 AM   #5
Integra's Avatar
I would personally pull it apart and do a quick inspection, there should be No binding what so ever.
Old 12-04-2010, 11:08 AM   #6
Suspended
Trader Rating: 440 (99%+)
+1
I've seen where too much loctite on the set screw will cause it to bind up at an angle if excess loctite gets all over the pin and driveshaft end and then dries. And I'm referring to the actual cvd assembly on the end of the driveshaft where it bolts to the pinion. I would take it completely apart and clean it all and then just use a dab of loctite on the set screw when you reassemble the driveshaft.
MattP is offline   Reply With Quote
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
