Old 11-27-2010, 05:54 PM   #1
Mind_Reader7's Avatar
Default Tmaxx 3.3 carb keeps sticking
Finally got my Tmaxx to a point of running. I replaced the engine casing yesterday because I overtightened a headbolt and stripped it. The bearings seemed bad anyway.
Engine has great compression, basically like new, however the brand new carb seems to stick. The throttle will open right up, then get stuck in certain spots on closing. What could be the prob? Might I need to roate the carb a little or something? I tried playing with the spring that connect to the throttle arm, and that helps sometimes, but the force basically stops me opening it fully.
Mind_Reader7 is offline   Reply With Quote
Old 11-27-2010, 05:57 PM   #2
Also, I had it running some time ago, and at about 5kph I knocked the left wheel on a wall, and the suspension arm snapped. I took a look, and whoever owned it before me had actually managed to snap the pins that connect the suspension arms. As to how he did it, I got no idea. That's fixed up though
Old 11-27-2010, 06:35 PM   #3
I rotated the carb slightly and it seems to be fine. If it happens agian I'll report back.
having problems with my tmaxx/new to nitro bdyman Monster Trucks 40 09-19-2010 07:26 PM
