Old 11-19-2010, 04:49 AM   #1
pballer2777's Avatar
Trader Rating: 27 (100%+)
Default Tire compound vs outside temp
Just wondering when some of you are switching tire compounds due to the change in temp. In the summer here I can use med compound, but when should I switch to using a softer compound. Is there a certain temp where you change?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 11-19-2010, 07:07 AM   #2
You know I have heard a lot about changing tire compounds due to the ambient temp rising but they doesn't really work here in florida. If we followed that strategy we would be running XTR's all the time but we usually go the other way using M3's, Softs, and Blues.
I think you need to look more at the balance of Tire Wear Vs. Traction and what our overall trying to achieve, if that makes sense. if your burning off a set of soft tires in one run just to be fast or running a little harder tire so they last at the sacrifice of traction.
I know Pro-Line has on their website a good guide for Temp V compound
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 11-19-2010, 07:50 AM   #3
i was more talking about goin from 90's and humid in the summer to 50's in the fall. maybe even some 40's
Old 11-19-2010, 09:42 AM   #4
Stubbs's Avatar
Trader Rating: 57 (100%+)
Good rule of thumb, unless you're a sponsored driver and get tires free....
Above 80-85 deg. F = med / M2 / yellow (JConcepts)
Below 80 = soft/ M3 / Blue
Once you get down to the 40's or below, start looking at Super soft / M4.
If tire wear is not a concern, you can run a softer compound for traction, but you have to watch for the tire getting too hot in a long main. If that happens, your car can start getting unpredictable. What I listed is a.good compromise between tire wear and performance. The tread pattern will obviously have an impact on wear as well.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Traction Compounds : Health Risks : what can we do about this? Martin Crisp Electric On-Road 785 06-11-2007 02:49 PM
Sorex vs Pit Shimizu Jared Kirkwood Electric On-Road 19 06-13-2002 08:28 PM
