Old 11-17-2010, 08:28 PM   #16
jmackani's Avatar
Trader Rating: 14 (100%+)
Same experience, started with the losi box, burned out the motors and moved over to the ofna truggy and never looked back. I have two of them now for both my son and I.
jmackani is offline   Reply With Quote
Old 11-17-2010, 08:37 PM   #17
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Originally Posted by inferno13 View Post
JEEEEZE..... and i thought you where a losi guy....lol, not a true supporter i see
I'm definitely a losi supporter, but losi or not I don't run it if it is junk. That's been my luck with losi starter boxes so far.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 11-17-2010, 08:42 PM   #18
LOSInit's Avatar
Post
I bought a RTR losi truggy about a 1 1/2 years ago . My little pink losi box has broken in several motors and traveled to several races. I use it for both my buggy and truggy all the time. I use 2 el cheapo 1300 mah batteries in it too . never had a problem . just throwin that out there.OH, btw i always pre heat motors on break in . good luck all
LOSInit is offline   Reply With Quote
Old 11-18-2010, 11:49 AM   #19
Gopher15's Avatar
I have the new Losi box with a lipo and it had no problem with my OS .28, but I do pre heat my motor, not for saving a bump box but for adding life to the motor. I had 2 chrome top ofna boxes when i ran my SC8 and my MBX-6. Yes they have good power but heavy and a pain to get everything to line up. Losi just works, period. One box for both truggy and buggy.
Scott Hurley
Boys Makin Noise Hobbies/Kustom RC Graphics
Gopher15 is offline   Reply With Quote
Old 11-18-2010, 02:51 PM   #20
offroad racer's Avatar
I got the upgrade one form losi(universal buggy and truggy) and it works amazing, once the engine has been broken in/lost its pinch
Losi 8ight-T 2.0
Losi 8ight 2.0
TLR 22
Ofna Nitro DM1
offroad racer is offline   Reply With Quote
Old 11-18-2010, 03:46 PM   #21
Originally Posted by jwm2 View Post
I'm really glad i did, it makes starting so much easier, i don't even have to preheat my engines anymore, even though i should :/
Wow, your engines still have that much mechanical pinch? A strong starter box is great, but shouldn't be a substitute for proper pre-heating and break-in. Cold starting a motor with mechanical pinch is one of the best ways to ruin engine life.
TPJ International
071crazy is offline   Reply With Quote
Old 11-18-2010, 04:35 PM   #22
+1. Use a heat gun while motor is new. After that no problem. But yeah the blue ofna box will be the one i get when mine dies!
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 11-18-2010, 07:04 PM   #23
golferdude1971's Avatar
Trader Rating: 18 (100%+)
The 2 550's aren't enough either. I was having one hell of a time cranking over my go engines when they were new, even after heating the engine 10 minutes with a heat gun to 300F. Once i bought the dynamite starter boxes (one for buggy, one for truggy) with dual 775 motors i no longer had any issues what-so-ever. I got a good deal on them ($49.99/ea) so i figured i'd give them a try. I'm really glad i did, it makes starting so much easier, i don't even have to preheat my engines anymore, even though i should :/
300 Degrees? Like 071 stated, you should pre-heat your motor before every time on the track. Cold starts are no good for your engines. A good product to invest in would be a Competition Heat R/C racing engine heater. This would definitely prolong your r/c engine's life.
golferdude1971 is offline   Reply With Quote
Old 11-18-2010, 08:30 PM   #24
boxhead's Avatar
Default Mugen off road starter
I use one of these with LiPo battery.
http://www.amainhobbies.com/product_...arter-Box-Gray
MBX6T M-Spec, MG66 Combo, Savox servo's, DX3S.
Lets go racing :)
boxhead is offline   Reply With Quote
Old 11-18-2010, 08:41 PM   #25
Suspended
Trader Rating: 202 (96%+)
Ill stick with the losi box!! never a problem!!!!
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 11-18-2010, 11:59 PM   #26
I love my Losi starter box, the ease of using both buggy and truggy on it with just a turn of a latch is great. I have however gone through 2 belts which I have put down to letting my battery get low on power which puts a strain on the belt. Keep the battery full and you should be sweet. That is just my experience with them.
Sworkz 350T
bopracer is offline   Reply With Quote
Old 11-19-2010, 12:20 PM   #27
builtb16a's Avatar
broken record right? anywyas.. yeah, i use the losi RTR box as well. i removed the engine, and aligned it perfect. i use a 3S lipo, and ive never had a issue turning over a PREHEATED engine.
usually, everywhere i go has 110V. so i use a heat gun to preheat my engine. i have a comp. heat head heater as well, but to break 180 degrees usually takes 20-25 minuets. i can get it to 180-210 degrees in about 30 seconds with a heat gun. and i like to warm, not MELT the block as well, helps saturate the heat and make it more consistent the second i hit the track.
never had a conrod fail, or bearings gum up... dont' want to start firing engines cold and find out. i'll preheat mine and have instant performance.
builtb16a is offline   Reply With Quote
Old 11-19-2010, 12:38 PM   #28
dash riprock's Avatar
My belt broke not long after purchasing my Losi 2.0 box.I replaced it with a belt from Korea I found on Ebay.The belt I found was 100 times better than the original Losi rubber band.Other than that I like the box.
Tony Hopcraft
Losi 8ight-T 2.0 Losi 8ight 2.0 Losi Mini-Late Model,Losi L8ight Model
Hobby Revolution Team Driver
dash riprock is offline   Reply With Quote
Losi Starter Box F/S F/T jldjlaudio R/C Items: For Sale/Trade 8 05-23-2009 05:47 AM
losi starter box rjs_13203 Nitro Off-Road 8 09-02-2008 05:05 PM
Losi Starter box layedbackguy Nitro Off-Road 17 03-14-2008 09:56 AM
Tags
losi 1/8 nitro starter
