Old 11-14-2010, 05:50 PM   #1
dishsoap's Avatar
Default My New Favorite Tool No More Dremel
My new favorite tool. No more changing out cutting discs hopping to get the stripped screw out.
I had a very small screw strip out on the top of the front carbon plate on my mugen. Couldn't get it out and because it sits flush and the dremel would cut the plate.
I popped the smallest one in my hitachi driver and in about 15 seconds the screw was out. First bore it with one end in reverse and then flip the bit and use in reverse again and viola. Works like a charm.
http://www.sears.com/shc/s/p_10153_1...&blockType=G14
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
Old 11-14-2010, 05:54 PM   #2
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
been using those for years
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Old 11-14-2010, 05:56 PM   #3
Suspended
Trader Rating: 202 (96%+)
i also have these, they work great on tiny screws and bolts, but dont work well on anything 1/4 inch or bigger
D8 "HARA", OS SPEED, ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
D8T GO GXII ,SAVOX 1267/68 SERVOS, BYRONS 25%, SPEKTRUM DX3R PRO
NMRCC -(northern michigan rc club)
inferno13 is offline   Reply With Quote
Old 11-14-2010, 08:26 PM   #4
Trader Rating: 21 (100%+)
there is an extended version of it goes for $40 it has 6 bits and you can use it on bigger size screws also.
TopGearRC is offline   Reply With Quote
Old 11-14-2010, 10:33 PM   #5
jwm2's Avatar
An easy-out is your secret weapon? Sorry i'm abit bummed, i was expecting to see something cutting edge. Those have been around for ages and are available at ALL hardware stores and even walmart. Theres times when those will not work, mostly when dealing with set screws.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 11-15-2010, 02:22 PM   #6
I think the set you ment to list was
http://www.sears.com/shc/s/p_10153_1...2155000P?mv=rr
Much more than a set of eay outs. I wish you could buy them at hardware stores or Wally World. I have had great success using them on set screws. Careful with the smallest one tho, easy to snap off. Have used on 4-40 screws tho they list the smallest it will work on is a 5-40.
bentgear is offline   Reply With Quote
Old 11-15-2010, 04:16 PM   #7
tony montana's Avatar
Trader Rating: 65 (100%+)
I have the exact set as you have dishsoap. I never had any luck using them.
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 11-15-2010, 06:35 PM   #8
jmackani's Avatar
Trader Rating: 14 (100%+)
alden makes the same things and you can get them at lowes.
jmackani is offline   Reply With Quote
Old 11-15-2010, 07:17 PM   #9
But the one at Lowes is too big.
Old 11-15-2010, 08:26 PM   #10
jmackani's Avatar
I have used both of the smaller bits from lowes on my cars with no problems. Once you drill out the hole, the size is fine.
Old 11-16-2010, 01:40 AM   #11
dishsoap's Avatar
Wow that's odd. It worked like a charm for me and on the first try. Hmmmm
Old 11-16-2010, 08:07 AM   #12
have same thing. Works 50% of the time. If your screw is really stuck you will have to dremmel it.
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 11-19-2010, 04:12 PM   #13
bjr48's Avatar
Try these for socket head fasteners...
http://www.sockitout.com/index.html
bjr48 is offline   Reply With Quote
Old 11-19-2010, 07:05 PM   #14
Marcus Falconie's Avatar
They go dull fast and then stop working
Marcus Falconieri
2011 Xray 808
Torco Racing Fuels
KBRL Nitro Series
www.youtube.com/gsadvanced
Marcus Falconie is offline   Reply With Quote
Old 11-19-2010, 10:17 PM   #15
ScottyM's Avatar
Trader Rating: 27 (100%+)
I had a motor mount bolt seize, and not even a dremel would free it up.. We ended up taking the other 3 motor mount bolts out, and spinning the motor mount to get it to break loose.. All jsut so Icould reset mesh.. next round mesh still wasn't right, and bolt as frozen again.. I ran it with too much slop in the mesh all summer.. It sounded horrible, but both gears looked good, and never had any troubles..
Scott Musgrave
ScottyM is offline   Reply With Quote
How to solder correctly (a not so brief lesson) marine6680 Radio and Electronics 542 06-07-2017 06:14 PM
