Old 11-09-2010, 10:09 PM   #1
melonpeel's Avatar
Default Reuse or Retire?
Do you grab a screw, inspect the head, and if it's used find a new one.. or use it anyway? Wheels.. are you always getting fresh rims with your rubber, or reusing your wheels?
Tekno 8B, Losi 8T
melonpeel is offline   Reply With Quote
Old 11-09-2010, 10:22 PM   #2
dnebout's Avatar
Trader Rating: 32 (100%+)
If the hex is sloppy on a screw for a metal to metal connection, I'll grab a new one. If it's a screw going into plastic, I'll re-use it. If the threads are stripped or damaged, I'll replace.
I just started dipping used rims in acetone, reusing foams, and gluing new tires. Saves a some money and now I have fresh rubber at every race. I used to run my tires until they were almost bald because I felt guilty (i get bad buyers remorse). Now that I've been gluing, I stick to the track and no more remorse for throwing away used tires.
Losi 8T 2.0, Werks B5 Pro, Savox 1267 / Hitec 7950
Losi Eight 2.0, Nova 4c, Hitec 7940 / Hitec 7955
Losi Eight E 2.0, RX8, Tekin 1900kv / Hitec 7955
Blackjack 26
Aka: Deebo, Poppa Pump / Busted Knuckle Wheelin' / Henchmen Racing
dnebout is offline   Reply With Quote
