Old 11-05-2010, 04:47 PM   #1
ckblood05's Avatar
Trader Rating: 15 (100%+)
Default t-maxx not starting.
i just got a used t-maxx 3.3 today. it only has 2 tanks ran through it. everything is there to run, but it wont start. has good compression. sounds like it wants to start. the guy said it has been sitting for a while. so the carb is probably gummed up? is there anything i can do to try and start it? i called hobby town usa and they said something about resetting a needle valve or something? then the guy i got it from said that has already been done. im new to all this nitro stuff. i drove a t-maxx for like 20 minutes a few months back. any help would be greatly appreciated!
traxxas t-maxx 3.3 model#4908 hopped up from the ground up!!!!!!!
duratrax 1/18 mini quake 4wd every part is upgraded!!!!!!!!!!
trinity spyder 4wd. 1/18 stock
ckblood05 is offline   Reply With Quote
Old 11-05-2010, 05:00 PM   #2
kaptain crash's Avatar
Trader Rating: 32 (100%+)
Send a message via Yahoo to kaptain crash
did u prime it by holding ur finger on the pipe? make sure your glow plug is getting bright orange, can take the plug out and prime it good, making sure fule is getting to the plug....should be spitting fule up through the glow plug hole....could be a few different reasons why shes not wanting to fire.
YEAH IM OLD...RUSTY AND SLOW,CRASH A LOT TOO. BUT WITH NITRO I HAVE A BLAST!
kaptain crash is offline   Reply With Quote
Old 11-05-2010, 05:02 PM   #3
ckblood05's Avatar
yea i tried holding my finger over the pipe a little. the plug glows. i can try taking the plug out and see if fuel comes up.
Old 11-05-2010, 05:34 PM   #4
ckblood05's Avatar
ok, i primed it and it actually started! it ran for about 2-3 seconds. then i started it again and tappede the trigger and it moved about 2 feet then stalled. after that, it wouldnt start again. like i could hold the button down for periods at a time on the starter wand. but after it started, it would only turn it over a couple seconds then stop. then i had to wait about 15 seconds and try again and only cranked over a couple seconds. could i have flooded it? or maybe the fuel wasnt primed any more? another thing, the fuel is 20% traxxas fuel. its like a year old. i guess the same as the truck. but i noticed the smell really isnt strong. im not real sure what it should smell like? but its almost like smelling water..... plus i dont have any after run oil.
Old 11-05-2010, 05:38 PM   #5
Mugen racer123's Avatar
Just buy new fuel and then try it. The alchohal probably evaporated
Mugen Mbx-6r ninja
Mugen Mbx-6t Ninja .21/2062
aka
Futaba
IVAN AGUILERA
Mugen racer123 is offline   Reply With Quote
Old 11-05-2010, 05:42 PM   #6
try putting it up on blocks to start it....the wheels should not move at low idle. it might be getting to much fuel to idle also.
Old 11-05-2010, 05:44 PM   #7
+1 on that fuel...you can use wd40 for after run oil.
Old 11-05-2010, 05:48 PM   #8
ckblood05's Avatar
ok, i might try it one more time w/ the wheels off the ground. then i can get some new fuel. one time earlier before i tried to start it this time, i tilted it on the side and a bunch of like brownish oily stuff came out the muffler. and even now sometimes a little comes out. im guess its probably gummed up,dirty inside. but i have no idea how to take it apart to clean it out.
Old 11-05-2010, 05:51 PM   #9
Trader Rating: 21 (100%+)
I didn't realize til now, you got another battery in this deal didn't you - one for the ez starter? You need to charge that tonight so it'll be fresh and fully charged for tomorrow.
I've had mixed results with old fuel, some brands it doesn't seem to bother and others it seems to make go bad.
You may want to remove the plug and turn the whole thing upside down and crank it over to blow out any raw fuel sitting in the bottom end. I'd do that before trying some fresh fuel. Make sure theres no dirt sitting around th eplug so nothing falls in the cyl.
Duster_360 is offline   Reply With Quote
Old 11-05-2010, 05:52 PM   #10
Trader Rating: 24 (100%+)
Lean out the low speed needle.
Your factory 3.3 settings are 1-1/2 out on the LSN or flush with the throttle horn and 3-1/2 to 4 out on the HSN. Tune from there.
got_nitro is offline   Reply With Quote
Old 11-05-2010, 05:55 PM   #11
440swinger-kid's Avatar
Trader Rating: 50 (96%+)
Have fun with that.... Glad how much of my time you wasted..... Dude dont even know how to plug a radio system in.... Hey make sure you buy all the aluminum upgrades you can.....lol
Savage Flux HP on 6s..... Tons of mods on the way..... AGAIN!
440swinger-kid is offline   Reply With Quote
Old 11-05-2010, 05:55 PM   #12
dont worry about that suff comming out of the pipe...the motor was just loaded up...the pipe will clear itself out when the motors fires up and runs for a few. how cold is it there?
Old 11-05-2010, 05:57 PM   #13
Like I told you last night you wont be able to tune it since its 40 degrees here now... more than likely when that guy ran it, it was 80ish.
Replace fuel lines and add fresh gas they are gummed.... Also you plug is gonna be wrong for the temp outside like I told you last night.
Old 11-05-2010, 06:03 PM   #14
ckblood05's Avatar
yea i put my sons 7.2v 600mah duratrax pack in for the ez-start. its completely charged. yea, i could do that. it will be next friday before i can buy anything. thats when my next check is.
Old 11-05-2010, 06:04 PM   #15
ckblood05's Avatar
its 37. but its like 65 in my garage. thats where im starting it.
T-Maxx Official Thread! macnkitty2002 Monster Trucks 685 08-24-2011 07:54 AM
T-MAXX WILL NOT SHIFT TMaxx-25 Monster Trucks 22 01-17-2008 08:17 PM
JUST BOUGHT A T-MAXX... MONSTER_JAMZ89 Monster Trucks 82 07-25-2005 04:35 AM
T-Maxx vs. Savage SS RC311 Monster Trucks 74 11-24-2003 03:13 AM
