Old 11-04-2010, 07:55 PM   #1
Default it finally happened
i stripped a screw and its on the radio box.. the screw head stripped and i dont know how to get a stripped screw out
Cdj1091 is offline   Reply With Quote
Old 11-04-2010, 07:56 PM   #2
mattleegee's Avatar
take a picture
AE ft b4.1 Ballistic 13.5 + SXX comp v2 (3-5-3-8) 1258tg
AE ft b4.1 Ballistic 17.5 + SXX comp v2 (3-7-0-4) 1257tg
BRCR
I pick things up and put them down
mattleegee is offline   Reply With Quote
Old 11-04-2010, 08:19 PM   #3
Send a message via MSN to Hyper RX7
yeah it's a pain....
I usually get a dremel with a thin disc and make a slot in the head of the screw.. Then use a normal flat screw driver to un screw it..
Can also use:
http://image.made-in-china.com/2f0j0...ew-Remover.jpg
Made for the job, but I haven't had much luck with them.
Hyper RX7 is offline   Reply With Quote
Old 11-04-2010, 08:40 PM   #4
ScottyM's Avatar
Trader Rating: 27 (100%+)
The dremel disk works 99% of the time..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 11-04-2010, 09:13 PM   #5
so you drill it out and then use a flathead to remove it?
Old 11-04-2010, 09:21 PM   #6
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
no just cut a line in it like on a flat head screw. no drilling necessary
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 11-04-2010, 09:50 PM   #7
melonpeel's Avatar
no drilling, just cut a slice on the head of the screw right down the middle with this -
Tekno 8B, Losi 8T
melonpeel is offline   Reply With Quote
Old 11-04-2010, 10:31 PM   #8
well how much does that cost? and it just attaches to a power drill?
Old 11-04-2010, 10:35 PM   #9
heres a quick trick that might work
take some aluminum foil and put it over your hex wrench
it'll fill the space and should hopefully get the screw out
car:losi 8ight
engine:werks B3, Novarossi P5XS
radio:DX3R,Ace DS1313
vroom88 is offline   Reply With Quote
Old 11-04-2010, 10:37 PM   #10
GizmoJunkie's Avatar
You can put them on a drill however a drill doesnt really spin fast enough to get it done rite. They are for a dremel tool.
If you dont have one i would recommend one, very handy when you need it. Probly thousands of little bits you can get for it. A decent dremel will run at least $40 and up. And these bits you can find in attachment kits, or seperately for usually $10 or less.
Im sure prices vary...
Some/most? dremels these days come with a small attachment kit usually including some of these. Can usually find them in a hardware store or walmart.
GizmoJunkie is offline   Reply With Quote
Old 11-04-2010, 10:51 PM   #11
jwm2's Avatar
Always keep a dremel handy. If you don't have one see if a buddy or neighbor does, most people these days do. I have a couple but have just recently realized that wired and not wireless is the way to go, expecially for long projects. Best $60 you'll ever spend.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 11-05-2010, 03:14 AM   #12
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
The aluminum foil works but what also is great is borax cleaner. But if it still does not work then you have to go the dremel route. Just remember if those disks break they EXPLODE so please wear safety glasses!
awdcameolsx is offline   Reply With Quote
Old 11-05-2010, 04:29 AM   #13
Or you can use a left handed drill bit, just remember run the drill in reverse.
rsmith569 is offline   Reply With Quote
Old 11-05-2010, 11:04 AM   #14
thanks guys, i will try the foil and cleaner method and if that doesnt work then i'll ask the neighbors for a dremel lol
Old 11-05-2010, 11:28 AM   #15
motomatt's Avatar
Don't forget to offer to let them drive it if they loan you the tool.
motomatt is offline   Reply With Quote
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread 4times Electric Off-Road 18372 07-17-2017 01:05 PM
TAOB Racing! Bring it!!! charlie_b California Racing 9502 07-04-2016 12:35 AM
Circuit City is Finally DEAD!!!! speedemall Chat Lounge 24 01-19-2009 01:26 PM
