Old 11-04-2010, 06:58 PM   #1
Default trying to set toe..1/8th scale
ok im trying to set my toe for my 8ight 2.0. i couldnt find an 1/8th scale toe guage so i didnt buy one. but i have a camber gauge and a set of calipers. can some one give me a detailed description on how to set the toe w/o a gauge. pics would be nice!!!
THANKS
skyler hays is offline   Reply With Quote
Old 11-04-2010, 07:30 PM   #2
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
THANKS
If you have a flat surface like a set-up board or piece of flat plywood, put it vertically on the edge of the table, so that your flat surface makes a 90 angle with the table. Then, with your car on and your trims set, push the car up against the vertical board. Set your camber gauge to whatever you want your toe to be, and place it on the vertical board and adjust the steering links.
That might be hard to understand... If you have any questions, just ask. I will try to answer with a clearer response.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 11-04-2010, 07:54 PM   #3
i think i understand...maybe some other folks will chime in too.
thanks for the help
Old 11-04-2010, 09:22 PM   #4
So*Cal AFDude's Avatar
Trader Rating: 21 (100%+)
i use a gauge for my camber...then eyeball my ride height and toe. close is good enough for me.
-Aaron Willming
~ Hobby-Pro USA ~ Viper-RC ~ IERC Raceway ~
www.IERCRaceway.com - www.Facebook.com/IERCRaceway
So*Cal AFDude is offline   Reply With Quote
Old 11-04-2010, 10:40 PM   #5
modified763's Avatar
Trader Rating: 73 (97%+)
Make sure that you adjust your camber first, then your toe. Camber changes your toe. You might have to go a little camber, then toe, then back to a little camber adjustment, then toe again. You'll find the sweet spot. Good luck.
Team Hot Bodies, Team O.S.Engines and Glow Plugs, Team AKA Products,Team Boca Bearings, Team O'Donnell Speed Blend Fuel, Team Upgrade RC, Tesla, Billy Oceans
modified763 is offline   Reply With Quote
Old 11-05-2010, 05:53 PM   #6
Mel
Mel's Avatar
Trader Rating: 34 (100%+)
i always wondered if your tring to get 3* of toe out in the front .. would you go 3 on each wheel or 1.5 on each wheel ?
i always wondered this when reading different set-up sheets
Mels Shells - Tekno RC - Blok - Boca Bearings - Sweep Racing Tires USA -
Mel is offline   Reply With Quote
Old 11-05-2010, 07:07 PM   #7
Peter Martin's Avatar
Per side...3 is 3 on each wheel.
Peter Martin is offline   Reply With Quote
Old 11-05-2010, 07:09 PM   #8
Mel
Mel's Avatar
Thanks Peter..
I did like the feel for the car with ether 2.5* or 3 out on the front .. but then i tried the 1.5( which in this case i thought i was doing 3 total ) and lost a ton of turn in
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
1/8th Scale On-road kevink2 Oval, Larger Scales and More 3016 07-18-2006 09:15 PM
