Old 11-04-2010, 09:06 AM   #1
Trader Rating: 22 (100%+)
Default Clutch spring size question
I have a question about Mugen spring sizing. I have an older but fast Mayhem that I run on a decent size oval. Track is smooth, packed and dusty. I'm using a 3 shoe clutch and was wondering which spring size would be best. We're only out of the throttle for a short time through turns. I need new shoes & springs. Should I get the .9, 1.0, or 1.1 Mugen? I haven't long gotten into the hobby from nitro boats. Spring sizing is one thing I haven't experienced yet.
Landmines is offline   Reply With Quote
Old 11-04-2010, 09:19 AM   #2
Id ask others at the track what they are running. But as a rules, larger springs engage later or at a higher rpm, lighter springs at a lower rpm. You might find that a few guys are running one 1.1 spring and 2 1.0 spring.
Im the wrench man
Boca Bearings~Pro-Line Racing~Radiopost~VP Pro USA
RcRacer37E is offline   Reply With Quote
Old 11-04-2010, 09:39 AM   #3
Suspended
If you don't need acceleration out of the turns, a soft spring will allow the motor to pull.
If you need the snap out of the turns, a heavier spring will be better.
Soft springs=Slipping clutch in a car @2500 RPM
Hard springs=Sidestepping the clutch at the same 2500RPM.
Storydude1 is offline   Reply With Quote
Old 11-04-2010, 09:43 AM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
As a general rule you want your clutch set up for the track surface and the engine you run. If your track is loose and your engine has Gobs of low end torque then if you set up your clutch to be too aggressive you will more than likely get allot of tire spin which equals wasted power and wasted fuel. If your springs are too light there will be to much slip before your bell engages your spur. As racer 37 said talking to the other racers is your best bet as there may be preferred clutch set ups for dirt oval and the track you race at. The examples I gave are for general off road and may change drastically for oval racing.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Losi Muggy question DHC6 Nitro Off-Road 9 03-17-2009 12:37 AM
Losi 8 Buggy clutch question NEMESIS44 Nitro Off-Road 8 05-27-2008 03:05 AM
Setting Question? JRGTR Nitro On-Road 6 01-29-2008 03:32 PM
