Old 11-03-2010, 10:41 PM   #1
Default Avid Bearings-help complete kit
Hi,
Could someone please help me to choose the correct set of Avid bearings from their website for my XB808 2010 specs?
Jaap is offline   Reply With Quote
Old 11-03-2010, 11:00 PM   #2
Trader Rating: 7 (89%+)
Hey there,
For the rear hub and front spindel you need 4 Pcs 13x19x4 and 4 pcs 8x14x4
For the Bulkhead Pinion Gear (Front and Rear) Assembly you need 6 13x20x4
For Diffs 6 pcs 8x14x4 (Use the composite Bearing Holder). This is what I use cause Its a lot lighter or you can use the bigger 8x16x5 (Not sure if its the correct dimension but its what I use for the Xb8. You dont need the composite bearing holder for this.
And the steering post bearing 4 pcs 6x10x3 (Not sure again cause I just re used this from my xb8. It fits most buggy steering post.
clutch bell bearing 2 pcs 5x12x4
Xray XB9/Kyosho MP9/Associated RC8.2/JQ The Car Yellow Edition
Mugen MBX6T
Techno RC EB8
oggietiu is offline   Reply With Quote
Old 11-05-2010, 01:11 AM   #3
Originally Posted by oggietiu View Post
Hey there,
Should I get Revolutions, ceramic revolutions, rubber or metal? If possible please specify the type for each bearing size.
Old 11-05-2010, 01:59 AM   #4
I did not get any ceramic ones cause I change bearing a lot. 5 is to 1 is the price ratio. My friends however told me that ceramics are way smoother and last longer so it really depends on what you want.
But just a tip for the bulkhead bearing ( Pinion Gear Bearing ) Get the ceramic ones. I will try this when my bearing get here.
Revolutions are one side metal shield and the other side rubber shield.
Mugen MBX6T
Techno RC EB8
Old 11-05-2010, 05:19 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
The revolution bearings are a good balance one metal shield and one rubber shield. Ceramic bearings in off road are a waste of time and $$. They get grity very quickly.
Old 11-05-2010, 08:57 PM   #6
yup was in the same line of thinking. but with the grease tip and bulkhead mod. ill try it with the pinion bearing assembly
Mugen MBX6T
Techno RC EB8
Old 11-08-2010, 12:12 AM   #7
I do not understand why I need the following bearings, where should I fit them:
8x16x5 Revolutions688-RSZ
13x20x4 RevolutionMR2013-RSZ
I only find the following in the mannual (excluding clutch bearings):
8x14x4 RevolutionsMR148-RSZ
13x19x4 RevolutionMR1913-RSZ
6x10x3 RevolutionsMR106-RSZ
Old 11-08-2010, 08:34 AM   #8
8x16's can be used on the diffs instead of the 8x14s with the sleeve...this is personal preference as these bearings aren't the problem, so you can use either one.
the 13x20 fit the '10 spec pinion/bulkhead housing
the 13x19 fit the '09 spec and earlier pinion/bulkhead housings
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
