Old 10-31-2010, 03:36 PM   #1
Default 1/8th scale toe gauge and setup tools
ok i have a 2.0 8ight and it has the rtr box setup on it. i am trying to put adam drakes standard setup on it and i have some questions.
i cant find an 1/8th scale toe gauge and i was wondering what you guys do or use.
im gonna pick up a camber gauge and i have a set of calipers. oh and instead of spending $10 on a ride height gauge im just gonna measure a dowel or something the length of the ride height i want and just slide it under chassis.
thanks.
skyler hays is offline   Reply With Quote
Old 10-31-2010, 04:37 PM   #2
alexrckid's Avatar
i managed to find two SPRAY PAINT CAPS.....one 42mm (rear) and one 39mm(front) high. after setting the respective ride heights, i use them to SPACE the chassis height so that i can set the camber correctly.....do the (front) toe setting after doing the camber.........changing the camber affects the toe setting. at the track, i use a camber guage to do the toe setting. twith the receiver and transmitter on and trimmed correctly, i stick a short (straight) length of 2x4 up against up against the front tires. set the camber guage to a few degrees negative and hold it up against the 2x4.....this is a great way to get(independently) both front wheels for the proper toe out.....
2008/2009 northeast super series Production MT champion
8T-2.0, werks B5, 2013, hitec's.
gallimods hobbies and raceway, barn/wolcott.
living in north myrtle beach. race at badlands
alexrckid is offline   Reply With Quote
Old 10-31-2010, 06:31 PM   #3
ScottyM's Avatar
Trader Rating: 27 (100%+)
thanks.
A camber gauge and a piece of 2x2 angle iron can be used to check toe..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 10-31-2010, 07:31 PM   #4
ok...when i get my camber gauge i will try it. if i cant figure it out i will get you guys to post up some pics.
thanks.
Old 10-31-2010, 07:57 PM   #5
ScottyM's Avatar
it is really easy.. Settle the chassis, then slide the angle iron up to the front wheels. Lay the camber gauge down, and put the bottom against the angle iron, then touch it to wheel.. Adjust tie rod until it is at desired Toe Angle..
Make sure to turn on radio so servo holds the wheels still..
Scott Musgrave
1/10 electric Offroad racing at Keilor rc1b4 Australian Racing 12188 07-30-2017 09:59 PM
5280 Raceway - Colorado On Road RC Club (CORRC) SlamMan Colorado Racing 21404 05-01-2017 07:55 PM
