D8 3mm chassis
D8 3mm chassis
Anyone had problems with them bending, seem to be very flexible when compared to the standard?
there have been reports in the uk that they go banana shaped without any significant abuse.
i have fitted mine today and seems quite weak compared to the 4mm or standard, was wondering if alloy braces would help reduce the front to back flex.
well i cant speak for the d8 i never driven it but i do run a 3mm tft flex chassis for the eight 1.0 t and its been pretty dam strong. no bending
i guess hb maybe hurry to fast to make it but it flexes so much that it bends ?
flex and bending are 2 completly diffrent things. Look at Xray they have lots of flex no matter what you do. If it flex its not bad, now it bending doesnt seem like the companies fault it seems like the racers is abusing it. Any chassis can bend if you case hard, also alloy braces wont cause the flex to really stop its just ganna cause flexing to occur some where else. Ive broke a engine block before on my jammin x1-cr team with all aluminum braces and etc because it had no where to flex but the engine case. Just keep in mind its a race chassis, dont club race it unless you want to but really no point to run it unless you in a series and a lighter car makes you faster. I like my 4mm thickness on my d8.
i dont know man i race with my tft 1.0 flex chassis on my 1.0 and ive had a couple of hard crashes and its fine im pretty sure its 3mm . made a big diffrence in lap times i club race
+1 a flex chassis on a rough track makes a big diffrence and easier to drive im sure it goes for the buggys also.
The chassis improves the handling by a good amount, but it fatigues quickly.
The chassis wear isn't the problem. The problem is that once the chassis fatigues it begins to over flex, if you will, and then tanks start getting hurt and front drive shafts get bent every run. At one point you'll have to unbend the chassis after every run.
have you guys notice that on teh 3mm chassis there is 2 extra holes that attacch teh chassis to teh rear front hinge pin... so if you getting that chassis make sue you get the rear front hinge pin holder form teh hara edition also.. or you will have to drill and tap to holes for your self.. my 3mm chassis came with those holes drilled out.. and it was not anodized so maybe it was an after thought to add reliability
when does that happen in about 3 gallons ? i dont run a d8 i have a 1.0 t with a flex chassis thats about 3mm.
For me it happened within 2 gallons, but our tracks are blown out with huge jumps. It was bound to fatigue the chassis soon. I think the euro drivers will appreciate the chassis since there isn't really any huge jumps or blown out tracks like in the States
That's a running change. The original 3mm didn't have the holes.
ha my track is blown out with one big triple but i double it to save the blow if i case it . i dont race every weekend so it should last more than 2 gallons
