Old 10-28-2010, 10:17 AM   #1
delane74's Avatar
Trader Rating: 38 (100%+)
Default changing fuel line on losi?
ok so yes this is a rookie question hut how do you change the line that goes inside the tank?
delane74 is offline   Reply With Quote
Old 10-28-2010, 10:23 AM   #2
CaseyP's Avatar
cut the line at either the inside before the clunk or the outside in front of the tank and pull it out. Then just thread a new piece of fuel line from the front side. (it helps to twist when you feed into the tank) when you get enough inside to grab it pull a bunch through and out of the lid. then install the clunk and pull the excess line back out from the front side. you want the clunk to sit right in the small recess in the very back of the tank
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 10-28-2010, 10:27 AM   #3
Jomo918's Avatar
+1 couldnt have been explained any better!
~~~~~ Joey Morales ~~~~~
Hotbodies D8T/Spektrum
Novarossi/AKA/Futaba
Heritage RC Raceway, San Diego CA
Jomo918 is offline   Reply With Quote
Old 10-28-2010, 11:31 AM   #4
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
once you get the line from the top add clunker place back-in should be in the corner then turn up side down side ways etc simulate a crash make sure it doesn't get hung up on the wall if it does just pull some line out.
Put some spit on the fuel line before entering the hole
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 10-28-2010, 12:17 PM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
Be careful not to pull the fuel lid back too far it will make the springs weak. I use a hex wrench across the tank to keep it open while I work on it. Also you can taper the edge of the fuel line to help get it started when you push it through and then cut it off before you put the clunk on.
Old 10-28-2010, 03:22 PM   #6
dash riprock's Avatar
I also like to wet the end of the new tubing with some fuel.I find it helps the new tubing slide into the hole in the tank much easier.
Tony Hopcraft
Losi 8ight-T 2.0 Losi 8ight 2.0 Losi Mini-Late Model,Losi L8ight Model
Hobby Revolution Team Driver
dash riprock is offline   Reply With Quote
Old 10-28-2010, 03:29 PM   #7
tomdex's Avatar
Trader Rating: 4 (83%+)
All good tips. Also make sure that the fuel tube you use is adequately flexible, to allow the clunk to 'hang' back onto the roof of the tank when the car is upside down. I've noticed the original Losi tubing is very soft and flexible, compared to some of the aftermarket fuel tube available. I've seen someone change it out and then they had trouble with flaming whilst upside down, because the clunk wasn't remaining in the fuel.
tomdex is offline   Reply With Quote
Old 10-28-2010, 04:04 PM   #8
Frank L's Avatar
I like to use kyosho line. It fits through the tank well and grips the clunk and inlet to the carb very tightly. Just my personal fav.
Old 10-29-2010, 05:46 AM   #9
That's the other thing. Be sure you use tubing with the same OD as the Losi tubing. Some tubing is a little smaller and will be too lose when you run it through the tank.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 10-29-2010, 07:10 AM   #10
I usually just take the lid off for this reason. I've been using Du-Bro "Nitro Line" with good success.
I find some good old spit works good for helping the line into the tank.
jay5280 is offline   Reply With Quote
New Hot Bodies Buggy!!??????? monsteraddict Nitro Off-Road 14489 03-18-2013 01:42 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi vs. ProLine Fuel Gun carlosm Nitro Off-Road 42 06-18-2009 02:21 PM
