Old 10-26-2010, 05:15 PM   #1
Trader Rating: 20 (100%+)
Questions?? Random Teeth On Spur Gear Missing???
I have 2 random teeth on my spur gear missing. Anyone know any reasons why? I already eliminated gear mesh because it wouldn't cause 1 tooth to snap off. It would grind down the spur/clutch bell.
Please enlighten me! Thanks!
quixoticboi is offline   Reply With Quote
Old 10-26-2010, 05:39 PM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
It could be a million different things. The one that would be on top of my list is a rock. I wouldnt worry about it, replace it and move on
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-26-2010, 05:41 PM   #3
Do I even need to replace it? It runs fine without the 2 missing teeth. They're not missing consecutively, by the way.
Old 10-26-2010, 05:55 PM   #4
smokinu's Avatar
Trader Rating: 60 (98%+)
replace it.
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 10-26-2010, 05:59 PM   #5
Call me ignorant. But why?
Old 10-26-2010, 06:00 PM   #6
smokinu's Avatar
replace it.
because its missing teeth..
Marcus P.
Old 10-26-2010, 06:02 PM   #7
What will happen if I continue to use it?
Old 10-26-2010, 06:08 PM   #8
smokinu's Avatar
more teeth will become missing
it might take out the clutch bell and spur if you let it get that far..
Marcus P.
Old 10-26-2010, 06:10 PM   #9
I still don't understand why or how this would happen.
I guess this is why I want to know what the problem is. If the problem was indeed a little rock getting caught in there, then I will continue to run the spur. If not, well, let me know what you think!
Old 10-26-2010, 06:12 PM   #10
smokinu's Avatar
do what you want to do, obviosly your to ignorant to see the point of missing teeth.
Marcus P.
Old 10-26-2010, 06:24 PM   #11
Ruune's Avatar
Send a message via ICQ to Ruune Send a message via AIM to Ruune Send a message via Yahoo to Ruune
you should only run with gaps in your teeth if you're southern.
now squeal like a pig...
Ruune is offline   Reply With Quote
Old 10-26-2010, 06:56 PM   #12
Hmm...
So run with a new spur because...
Still no explanation. I may be ignorant, but until there's some validity to the statement "cause you should", I won't...
Old 10-26-2010, 07:02 PM   #13
Your spur is missing teeth most likely from a slipper that is too tight and/or from a hard landing under throttle. Replace it or you will damage your tranny.
Steve. is offline   Reply With Quote
Old 10-26-2010, 07:03 PM   #14
newuserlosi8t's Avatar
Trader Rating: 65 (97%+)
Hmm...
the spur gear if u flip ur car over is open to rocks and crap a little rock got wedged in and caused a tooth to break most likley it happens all the time if u are running on a rocky surface,if u wnt to run it run it but having a gap will leave a space between teeth and will be easy for the teeth closes to it to be a weak point thus causing another tooth to break and lead to further problems, imo
just replace it thus eliminating further problems
zo1b team option buggy
mg66 go 2072 a main fuels savox servos
TEAM DRIVER FOR----ANSWERRC-USA--- PREMIEREHOBBIES--answerrcusa.com-http://premierehobbies.com ***Contact me for pricing and information on Argus, Hyperion, Max Amps, Durango and Savox***
newuserlosi8t is offline   Reply With Quote
Old 10-26-2010, 07:09 PM   #15
Finally some useful responses. Thank you!
Now I will replace it. (I'm not that ignorant, just need a reason to do things)
