Old 10-26-2010, 07:10 PM   #16
Illbreakthat's Avatar
The following teeth after the ones that are missing will now take more pain under usage. Even though only the one is missing the clutch bell is now transfering the power to a further point and now the next tooth has to carry a greater load. You can still run it the way it is but understand you have been given wise advise and when you rip another tooth it will take out your clutchbell on its way out, possibly damaging your clutch.
Not much to put here....
Illbreakthat is offline   Reply With Quote
Old 10-26-2010, 07:24 PM   #17
Jaz240's Avatar
Trader Rating: 52 (100%+)
or your crankshaft
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 10-26-2010, 08:01 PM   #18
nitroexpress's Avatar
Originally Posted by quixoticboi View Post
Finally some useful responses. Thank you!
Now I will replace it. (I'm not that ignorant, just need a reason to do things)
It's a Traxxas, you don't need no stinking spur gear replacement.
nitroexpress is offline   Reply With Quote
Old 10-26-2010, 08:04 PM   #19
Trader Rating: 20 (100%+)
I want to laugh but don't know why I would be...
quixoticboi is offline   Reply With Quote
Old 10-26-2010, 09:11 PM   #20
Ruune's Avatar
Send a message via ICQ to Ruune Send a message via AIM to Ruune Send a message via Yahoo to Ruune
because either your spur gear has a casting defect or it suffered impact at two different points. Either way, it's in a weakend state.
Additionally, when you're skipping a tooth, the clutchbell pinion gear gets slightly out of whack and it hits the next tooth on the spur gear just enough to tap it. multiply that by 40,000 times (at WOT) and you get the idea. They fall like dominoes.
Ruune is offline   Reply With Quote
