NEW D8 Atsushi Hara Edition*
#2433
I ran 98mm droop on the front of my car, its close to the end of te outdrive never popped out. With it set at 102 mm it was too close for comfort. The car seemed fine with the less amount of droop though, and the track i ran was pretty rough. Shrink tube the cvd pins and make sure the flat spot is against the set screw and it should be fine.
#2435
I have been running Hot Bodies for almost 2 years now and have never even seen this happen. Not to mention there are more than 5 people at my local track and they have never had this happen. I hear so many people say this but I just havent ever seen it.
#2436
I've tried the 3 HB chassis (3mm LW, 4mm LW, 4mm stock), Fioroni 3mm chassis, Tekno 4mm, and BCE and the HB 3mm LW and Fioroni 3mm are the two that worked the best for me.
#2437
trick body and J-concepts Losi 8t body.. ready for my HB... will have picts when i find the time to mount them
#2438
thanks Jesse! I'll just soften up the shocks to compensate for the weight loss. A properly setup light car is faster than a properly setup heavy car.
#2439
I am running on a fairly rough track, enough to upset the car going in a straight line. It also becomes pretty dusty and slippery. I have the hara chassis, but wondering if the old heavy D8 chassis might work in such conditions. Thought a heavier car can get better traction too.
Also, the team driver set ups we see, are they all using the light weight chassis?
The thicker chassis would not flex as much and possibly be more difficult to run on a rough track....the more that the chassis is able to flex the easier it will be to drive on a blown out track...All in my experience...
#2440
Hello guys , i bought my car Hara d8E with monster conversion .
i wanna change to nitro , which parts should i get ?
Clutch
Clutch Bell
Fuel Tank
Radio box
Engine mount
Throttle Linkage Set
Servo Horn
High Speed Servo
What else ?
Clutch
Clutch Bell
Fuel Tank
Radio box
Engine mount
Servo Horn
High Speed Servo
What else ?
#2442
anyone know when the new sway bar sets will hit US shores? are they EU exclusive?
