back pressure
back pressure
so i got a rtr rc10gt. the original still a blue chassis though. now, it came with a .15 which i still run. i had it completly taken apart and upon putting it back together i noticed my pipe was cracked, the end that mounts to the chassis. i cut it off making it prety much a straight blow threw pipe, now i go no fuel. i put a diff pipe on brand new same problem. why is my engine not getting fuel. if i hold my finger over the piece that comes off the pipe, then my fuel line will pump fuel, if i take it off, try as hell. what would coause this. keep in mind i did try a brand new pipe.
If every things fine with the pipe you might have a pin hole in your pressure line or maybe even in your tank. At least this is something to check.
could you put up some pics so we can see whats going on and what pipe is the new one?
