Old 10-22-2010, 09:13 PM   #1
gt fast's Avatar
Default back pressure
so i got a rtr rc10gt. the original still a blue chassis though. now, it came with a .15 which i still run. i had it completly taken apart and upon putting it back together i noticed my pipe was cracked, the end that mounts to the chassis. i cut it off making it prety much a straight blow threw pipe, now i go no fuel. i put a diff pipe on brand new same problem. why is my engine not getting fuel. if i hold my finger over the piece that comes off the pipe, then my fuel line will pump fuel, if i take it off, try as hell. what would coause this. keep in mind i did try a brand new pipe.
gt fast is offline   Reply With Quote
Old 10-22-2010, 11:26 PM   #2
Do-Over's Avatar
Your not getting enough pressure from the exhaust to push fuel up to the carb is what it sounds like... You say your pipe has a hole in it? Besides the stinger?
If every things fine with the pipe you might have a pin hole in your pressure line or maybe even in your tank. At least this is something to check.
AE RC8T, Futaba,A-Main by Massive Mods, Hitec,
JConcepts, Fastraxx Hobbies, Team Terribles,
Do-Over is offline   Reply With Quote
Old 10-24-2010, 01:57 AM   #3
RUNNINONMT's Avatar
could you put up some pics so we can see whats going on and what pipe is the new one?
RUNNINONMT is offline   Reply With Quote
xxx-nt back pressure line freeman Electric Off-Road 12 02-07-2004 12:53 PM
