Old 10-18-2010, 06:23 PM   #1
delane74's Avatar
Trader Rating: 38 (100%+)
Default losi shock mod
i keep hearing about this shock mod. is it the same as the rc8, with taking out the bladder and puting foam in the top with a small hole in the shock cap? what size of hole and how thick of foam?
delane74 is offline   Reply With Quote
Old 10-18-2010, 06:34 PM   #2
not sure what size whole but you still use the bladders. The foam goes between the bladders and the shock cap.
devilsquid is offline   Reply With Quote
Old 10-18-2010, 06:37 PM   #3
Here you go. If you have to save it to your desk top and then zoom in on it when you open it
Old 10-18-2010, 07:18 PM   #4
Azizi's Avatar
hai guy....thanks for share....if any different idea to mod that shock?
Azizi is offline   Reply With Quote
Old 10-18-2010, 07:32 PM   #5
the only thing I have heard that you can do different is use foam instead of CA gluing the o rings to the top of the cap
Old 10-18-2010, 07:49 PM   #6
delane74's Avatar
Default shock mod
thanks for info
Old 10-18-2010, 08:00 PM   #7
No problem man
Old 10-18-2010, 09:41 PM   #8
builtb16a's Avatar
yeah, i really don't want to drill holes in my really expensive alum shock caps.
might consider some plastics for this mod. if i don't like it, go back to my OE alum caps. hrmm..
builtb16a is offline   Reply With Quote
Old 10-18-2010, 09:50 PM   #9
losi_racer's Avatar
Trader Rating: 25 (100%+)
this is my opinion, but consider a lot of people love this mod.
I didnt like the mod, it made both my buggy and truggy not land off a jump or handle the bumps as well. in truggy it was as noticeable but i could still tell. In buggy i hated it, i ended up having to change suspension set up(oils and springs) to settle it back down. I recently bought a new buggy and truggy and i have not and will not mod the caps and they feel a lot more planted. Now the mod does its job, it keeps the ride height consistent as well as rebound.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 10-18-2010, 11:00 PM   #10
i just picked up a losi EU to test and this has the mod already done at the factory.
i used mike truhe's setup from the 08 worlds,big pistons front silvers,small rear green.
i didnt have any losi oil so used edit oil,40f,25r and the car lands like a wet rag in custard
it never double bounces and is super thru the bumps.
i built with only 5mm of rebound tho and it seems perfect.
Thankyou to my sponsors: : modeltune : Optifuel
fastboy is offline   Reply With Quote
Losi 8ight t 2.0 shock mod bacchus Nitro Off-Road 16 08-28-2015 08:34 AM
losi 2.0 shock mod ? PIMP_9000 Nitro Off-Road 63 03-23-2010 12:30 PM
losi shock cap mod mrbusta Nitro Off-Road 9 07-23-2009 05:12 PM
shock rebuilding and setup?????? busaboy Nitro Off-Road 19 07-09-2009 03:33 PM
