Old 10-16-2010, 12:25 PM   #1
Chadstrotheide's Avatar
Default losi 8ight eu setups
does anyone have losi 8ight eu setups?
Chadstrotheide is offline   Reply With Quote
Old 10-16-2010, 05:34 PM   #2
Show871's Avatar
150 wt in the shocks, and rotella 20/50 in the diffs. MRC hornet rears all the way around. Friggn dialed!
Show871 is offline   Reply With Quote
Old 10-17-2010, 01:09 PM   #3
Default eu set up
I have a eu buggy here in states. the front and rear shock towers are different otheter than getting all the stuff you need to buy for us car its the same. came with alumium front and read adj toe plates. Inclindes aluminum front spindels n carriers covered wheel nuts vented shock caps foam compansaters for shock mod and all syuuf is black not the losi brown color. i will get back with you in a lilttle while when get home and give you complete eu set up.
Rem578 is offline   Reply With Quote
Old 10-18-2010, 03:22 AM   #4
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
http://losi.com/ProdInfo/Files/2010GPMontpellier.pdf
i like this setup as a base mark
from there i run
i run 5F-7C-3R in the diffs
2mm rear sway bar
29mm rear ride height
bump steer up
3 degrees of rear toe in
2.5 degrees of antisquat
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 10-18-2010, 06:50 AM   #5
Show871's Avatar
Im just jealous your car will be tricker than mine, but I still think the MRC hornet rears all the way around will be awesome
Old 10-23-2010, 10:53 PM   #6
Talking
#871...the car might be a little tricker but it DOES NOT help you when you have cheap racers, doing take out moves....
its always faster when your RX battery gos dead wide open!!! lol
Old 10-23-2010, 11:28 PM   #7
i run truhes 08 worlds setup but with shocks on the outside on the tower,if track has big jumps with no downside,a tad heavier in rear oil helps.
Thankyou to my sponsors: : modeltune : Optifuel
fastboy is offline   Reply With Quote
Old 10-24-2010, 06:40 AM   #8
lanmine657's Avatar
your waisting time with setups, work on remembering which car is yours first!!!
Buggy on the Brain
MotoAdventure Kawasaki
LOSI
Riva-Sinister Skis-Jetworks-Jet Pilot
Coorslight
lanmine657 is offline   Reply With Quote
Old 10-24-2010, 03:30 PM   #9
Show871's Avatar
this is a great tip, and helps prevent going full throttle into 3' tall weeds
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
New Losi 8ight 2.0EU Buggy guss2009 Nitro Off-Road 96 01-03-2012 01:32 AM
