Old 10-10-2010, 02:29 PM   #1
Default why isn't my car shifting?
ok so today i started to drive my car (redcat tornado s30) and i noticed it was not shifting into 2nd gear. it had high rpms the whole time and was not going as fast as usual. the time before this time i drove it, it was shifting perfectly. when i had the thorttle pushed it went high rpm then lowered its rpms while i was still holding the throttle.
my transmission is a 2 speed by the way.
if this helped, a dog bone snapped the same time the transmission quit shifting. i replaced the bone and the tranny still would not shift!
what do i do?
zoot3546 is offline   Reply With Quote
Old 10-10-2010, 11:02 PM   #2
Trader Rating: 21 (100%+)
when you disassembled to replace the dog bone did you have to take the clutch or motor off also? if you did then go over the whole setup make sure everything is in place. Also check your clutch shoes, bell and bearings maybe something is stuck or need replacing. In any case disassemble the whole transmission, inspect everything and then put it back together according to manufacturer's specs.
TopGearRC is offline   Reply With Quote
Old 10-11-2010, 10:01 AM   #3
Integra's Avatar
Could be the tune on the motor, Try leaning it a hair and see what it does.
Old 10-11-2010, 10:28 AM   #4
Trader Rating: 20 (100%+)
I agree. My T-Maxx 2 speed was running a little too rich and wouldn't get high enough in the RPMs to make it shift. It was a simple tuning issue.
quixoticboi is offline   Reply With Quote
Old 10-11-2010, 10:29 AM   #5
what do i do?
You say it wasn't going as fast as usual.. Also leads me to agree with Integra to lean the HSN a bit and see what happens.
Old 10-11-2010, 11:25 AM   #6
jwm2's Avatar
Yeah try tuning it first and see if that helps. Otherwise there should be a tension screw in the tranny that changes the shift point (rpm).
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Formula 1... Darkseid Chat Lounge 14873 Yesterday 03:44 AM
Team Durango DEX410 ASH93A Australian Racing 925 04-08-2013 09:51 PM
I don't normaly post things like this but it kinda make sense Davin Chat Lounge 25 05-11-2005 06:18 AM
gear ratio 101 - gearing more important than motor? cybertoolzz Nitro On-Road 15 04-01-2003 05:49 PM
