Old 10-10-2010, 08:50 AM   #1
Default Buggy Wheelies= Not Good
Ok so the question is, how do I stop my buggy from doing wheelies after the jump landing. Seems like when I make the big jumps or even some 2-3 footers the buggy will do a wheelie when I land and ride it till I let off for the turn. Am I getting on the throttle too hard too soon? I want to try and make as much speed as I can and beleive the longer you are in the air the slower you are. Do I need to look at my shock weights? I have 400F and 350R in a MBX5R. Im a new driver and not too familiar with handling characteristics or racing so any help would be greatly appreciated. Thanks
mdavis1432 is offline   Reply With Quote
Old 10-10-2010, 09:01 AM   #2
Frank L's Avatar
Trader Rating: 148 (100%+)
That's an easy fix. Let off the throttle and then ease back on it. If you have too much snap then lighten up a spring or 2.
Old 10-10-2010, 09:02 AM   #3
kgombe's Avatar
what weight oil u have in the center diff
kgombe is offline   Reply With Quote
Old 10-10-2010, 09:03 AM   #4
5K front
7K center
2K rear
Old 10-10-2010, 09:05 AM   #5
awdcameolsx's Avatar
Trader Rating: 36 (100%+)
Try going up in rear shock oil a little bit or maby even the next stiffer spring if not both. Also try a less agressive clutch setup. Like if you are useing 1.1mm springs try 1.0's or, I always liked carbons with 1.0s on that car was always nice and smooth engaging where aluminum's usualy engage quick. That is somewhere to start at least.
Also make sure you are using the right gearing. Check the specs for your car I am not sure exactly how many teeth are supposed to be on each of the gears in that car. Top end wise do you keep up with everyone else?
awdcameolsx is offline   Reply With Quote
Old 10-10-2010, 09:06 AM   #6
kgombe's Avatar
ok.. u can try not to flat-land and punch it...... or down side the landing.. or go to 5 k in the center
Old 10-10-2010, 09:07 AM   #7
Just don't get on the throttle until you land. I don't know for sure, but it's probably not to good on the diffs either to be hammering the throttle as your landing.
bevofrancis is offline   Reply With Quote
Old 10-10-2010, 09:08 AM   #8
7k in the center is too much for a buggy, go down to a 5k or even 4k, it will solve your issue.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 10-10-2010, 09:08 AM   #9
kgombe's Avatar
making the back stiffer may cause more wheelies
Old 10-10-2010, 09:10 AM   #10
Im not on the throttle when I land. Its the split second after I land is when I get back on it.
What about letting it land and roll for a few feet then get back on it? Also only happens when I land flat not on the backside transition.
Old 10-10-2010, 09:12 AM   #11
kgombe's Avatar
flat landing could be the problem.... but going to lighter oil in the center could fix your issue or a lighter clutch spring as some else already suggested
Old 10-10-2010, 09:21 AM   #12
He is at 350 in the rear which is very light for that car IMO giving him more rear traction and weight transfer to the rear.
Old 10-10-2010, 09:27 AM   #13
kgombe's Avatar
more weight transfer will give more power to the front... rem. these cars have a center diff.. so the lighter the rear oil the more power is transfered to the front wheels.... and these diffs transfer power to the wheels with least resistants/ least traction.. making the rear stiffer will will give you less weight transfer and cause more power going to the rear and may cause more wheelies as a side effect... that being said ... his center diff maybe to stiff.. or is binding, causing it not to slip...
Old 10-10-2010, 09:38 AM   #14
j_blaze14's Avatar
Trader Rating: 34 (100%+)
too much motor, too much clutch, too much traction, to much spring on shocks, too tall a gearing. try to soften the clutch springs, try a bigger clutchbell and maybe a smaller venturi on the carb if all your oils are within range for that car.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 10-10-2010, 09:38 AM   #15
Jaz240's Avatar
Trader Rating: 52 (100%+)
His front shocks are too stiff causing the front to bounce up
nothing to see here................................
Jaz240 is offline   Reply With Quote
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11249 07-23-2017 01:50 PM
mid motor 2wd buggy conversion mopar1994 Electric Off-Road 486 10-29-2014 04:36 PM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 336 12-14-2009 10:22 PM
