Old 10-10-2010, 09:42 AM   #16
kgombe's Avatar
Originally Posted by Jaz240 View Post
His front shocks are too stiff causing the front to bounce up
yeah and this....
kgombe is offline   Reply With Quote
Old 10-10-2010, 11:45 AM   #17
Jerseyboy's Avatar
For me if the buggy wheelies after landing is always kinda cool. Sometimes you can enjoy it so much that you have mastered the art of wheeleeing your buggy. Its all in the drive style.
You problem is really throttle control. You on the throttle too early after landing. Most setups will make the buggy do that after landing. The buggy lands and the springs load up , you throttle and it wheelies.
Play around with your drive style and you will get your groove.
Just for info:
thicker centre oil reduces wheelie effect: eg to 10k
Also ride height. Make sure its level.
After ride height spring rebound. Thinner oil more bounce, thicker slower rebound.
Stiffer spring als requires thicker oil for same effect.
Hope this helps.
Jammin X1 FTE
Upgraded to Warp Drive
KO Mars Ex-1 Spectrum Telemetry
Jammin JPX 21/OS Speed
Jammin X1 CRT
Go tech 21 5p
Upraded to Stelar Galactic
Jammin X1 CRT.5
Power by SH12
Either your Jammin or losing"Catch me if you can"
Team Dramatic
Jerseyboy is offline   Reply With Quote
Old 10-10-2010, 12:19 PM   #18
kgombe's Avatar
Originally Posted by Jerseyboy View Post
Just for info:
are you sure about that.. it's the opposite to what i know and tested
Old 10-10-2010, 12:24 PM   #19
tc5 man's Avatar
10 k in the center of a buggy i dont think that would work to good.
Old 10-10-2010, 08:36 PM   #20
Tate72's Avatar
Trader Rating: 52 (98%+)
Well I know I moved my front shocks to the outer holes on top and it caused me to bounce like that so I moved mine back to the middle hole. What holes do you have your shocks mounted in? I run 5-5-3 in my buggy. And it seems to work pretty good. I'm still new somewhat so I try different things when I hear about them.
Team Durango, http://www.team-durango.com/
TrakPower Speed Equipment, http://www.trakpowerusa.com/
DE Racing, http://www.deracing.net/
WWW.JCPRCRACEWAY.COM
Tate72 is offline   Reply With Quote
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11249 07-23-2017 01:50 PM
mid motor 2wd buggy conversion mopar1994 Electric Off-Road 486 10-29-2014 04:36 PM
Academy's new 1/10 scale buggy SBV2 PRO rcforum Electric Off-Road 2964 12-10-2011 11:16 AM
1:8 EP BUGGY (CASTER) or ANY BRUSHLESS CONVERSION THREAD azmin Malaysian R/C Racers 336 12-14-2009 10:22 PM
