Old 10-08-2010, 01:34 PM   #16
Integra's Avatar
Originally Posted by -R2- View Post
Diff is in backwards, the diff gear should sit on the left side of the gearbox when looking at it and for both front or rear gearboxes.
Originally Posted by bmwpower88 View Post
the car was running fine before this happened...
Not possible R2.
Old 10-08-2010, 02:03 PM   #17
Originally Posted by Integra View Post
Not possible R2.
+1
so the car was fine 1second and not the next and there were no repairs made to it whatsoever in the meantime ?
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 10-08-2010, 02:11 PM   #18
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Looks like he was talking about spining the front wheels by hand and seeing the back wheels turning the opposite way, which would be explained by the blown out clutch bearings he found, Clutch locked up making the diff gears do their thing when he spun the wheels.
Replace clutch bearings and all should be good.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 10-08-2010, 02:38 PM   #19
-R2-'s Avatar
I assumed someone had worked on it.
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 10-08-2010, 03:21 PM   #20
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Originally Posted by NitroFreakManHo View Post
That still wouldn't be the cause of your wheels spinning in opposite directions..it's likely your diff.
Not true. If his clutch bell wouldn't move due to a bad bearing, it wouldn't allow the center diff to rotate... that will cause the symptom he described.
But thanks for playing!
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 10-08-2010, 03:23 PM   #21
DOMIT's Avatar
BMW,
Ignore the comments about the diff being backwards... yes, that can look like the same problem, but in your case it is just the clutch problem you found. Fix that and you'll be fine.
Old 10-08-2010, 11:22 PM   #22
ScottyM's Avatar
Trader Rating: 27 (100%+)
definitely something with the center diff or clutch....take it apart and inspect.
I reread and I am confused.. How can a CB bearing cause the wheels to spin in oppsite directions when on the box? If a brake was draggin it wouldn't let one set of wheels turn at all, and all power would go to the other end.. IF a gear is broken inside, it will simply lock the diff or slip with out spinning either set of wheels..
I still say it is a F/R diff in backwards..
Scott Musgrave
ScottyM is offline   Reply With Quote
Old 10-08-2010, 11:31 PM   #23
Originally Posted by (MRC)Scotty! View Post
Sorry Nick, but one of his diffs is installed backwards.. I know with Losi, you can install one way, but most other brands you can mess it up.. I always check during reassembly..
I know it has been said, but you have a diff gear installed backward. if the fronts spin backward when the engine turns them, then the front diff is in wrong..
Scotty you are ignoring the fact that the guy has said his clutch bearing has collapsed.
With the clutch working properly, you would be correct. When the clutch bell is solid and cannot turn, then the diff action will cause the wheels to go in opposite directions (turn your left front wheel and the front right will go in the opposite direction!!).
Flipfly is offline   Reply With Quote
Old 10-08-2010, 11:36 PM   #24
ScottyM's Avatar
Okay right on.. DUH, on my part.. But I read where he started it and the wheels were turning backwards..
i started the car airborne but wheels where still spinning opposite ways.
Scott Musgrave
Old 10-09-2010, 01:20 AM   #25
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
...yeah, I realized that just after I posted it
..it was fun.
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 10-11-2010, 06:33 AM   #26
If the clutch is locked spinning front or rear wheels will turn the center diff gears and cause the opposite wheels to turn backwards.
thats what happened. the clutch was locked due to broken gear.
bmwpower88 is offline   Reply With Quote
Old 10-11-2010, 06:34 AM   #27
thats what had happened. i changed the clutch bell with new gears and its working fine now.
Old 10-11-2010, 06:35 AM   #28
yes you know your thing. i have changed it and works good now. thanks
Old 10-11-2010, 06:36 AM   #29
yeah exactly what happened. diff has never been touched before. new clutch bell and gears and all is working now. thanks
Old 08-09-2011, 09:37 PM   #30
Default Simlar issue with Tamiya Plasma Edge
The FR and FL spinin opposite directions and the RR and RL spin in opposite directions. Would this likely be a differential issue?
greg_p is offline   Reply With Quote
Castle Creations Mamba/MM/MMM FACTORY Q&A thread! Joe Ford Team and Company Discussions 2371 08-07-2017 10:37 AM
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
Horsham Rc Carpet racing 2009 Jeff Cuffs Racing Forum 3890 09-12-2010 01:01 PM
HELP PLEASE CARS SPINNING 16skyline Electric On-Road 62 07-30-2007 01:32 PM
