Old 10-06-2010, 02:37 PM   #46
Originally Posted by JAMMINKRAZY View Post
The parameter reset doesn't require that you reset any of your settings.
Oh so nice!
So it's just a position recal for the pots? No harm in doing that regularly, no?
itbvolks is offline   Reply With Quote
Old 10-06-2010, 02:37 PM   #47
pyromania's Avatar
Trader Rating: 18 (100%+)
Originally Posted by jmaxey51 View Post
cant you cut the antenna shorter and its no biggy?
Not on the SR3100. Cut the coax cable and you're in for trouble.
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 10-06-2010, 02:38 PM   #48
CaseyP's Avatar
just like Jammin said you re calibrate and it won't mess with any other settings.
Most radios have to be sent back the manufacture to be re-calibrated.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 10-06-2010, 02:39 PM   #49
I just replaced mine as I got my rx with a cut antenna. Seems to work well now. 3-day event this weekend so we'll see how it works.
Old 10-06-2010, 02:50 PM   #50
Idk if someone said this or not yet, but I saw something similar and I am just throwing out my 2 cents...
Theres 2 ways to make the 2.4 band possible...
There the spread spectrum which has it's own specialized signal that binds the tx/rx together.
And there another type where the signal is jumping around constantly so it is never on the same channel for long. This is more complicated and could be what the 4pk uses?
The Spektrum radios could use the specialized signal type. So the 4pk could possibly interfere for just a second....
racerstf is offline   Reply With Quote
Old 10-06-2010, 03:30 PM   #51
Have you tried re-binding the radio/receiver? That could be the solution right there. Also make sure you don't have any wiring issues, put a new switch in and check your receiver's antenna for cuts.
I would also suggest setting your failsafe to neutral for a couple reasons. One being if it does go into failsafe on the track you won't be locking the brakes up in a bad spot(say the middle of the straight with 3 screaming demons behind you). And also if you happen to leave your electronics switched on with the radio off by accident you won't burn out your throttle servo from it sitting at full brake for a half hour.
I haven't tried rebinding my receiver, I also never thought of the failsafe like that. I have left my car on a few times with the radio off. I'll have to change that later.
bevofrancis is offline   Reply With Quote
Old 10-06-2010, 03:33 PM   #52
Originally Posted by deadmancourt View Post
that sounds like its your reciever pack,not the remote....i had the same issue...bought a new reciever battery and bamn...no more random glitches
I don't think the failsafe would kick in if it was my reveiver battery.
Old 10-06-2010, 04:01 PM   #53
pickle311's Avatar
Trader Rating: 31 (100%+)
Originally Posted by bevofrancis View Post
I've never heard of the KO radios, and tried to find their website online and can't. Does anyone have a link to their official site?
www.kopropo.com
They have been in the business far longer than Spektrum has been around. I remember drooling over the KO Mars 10 years ago but couldn't afford it.
Thanks to my sponsors and friends
RC America l Xray l Hudy | Pro-Line |KO Propo | Avid | VP Powermaster
pickle311 is offline   Reply With Quote
Old 10-06-2010, 04:02 PM   #54
steve307b's Avatar
Trader Rating: 23 (100%+)
Originally Posted by itbvolks View Post
Looks almost as bad as the moldy barf KO....
While I love KO stuff and used their servo's forever, their Tx looks like something out of a bad 80's movie....
I've been pretty happy with my 3R. Light, easy on batts, small, has everything I need in a Tx and Chad's wrap looks bad arse on it
I agree, they are some ugly A$$ radio's. Also reminds me of the RTR slash the way the handle is....uuuggg
8ight-T 3.0 **FX Royal Engine** 2013- Savox 1267/Hitec 7950
Henchman racing
DX4R
steve307b is offline   Reply With Quote
Old 10-06-2010, 05:00 PM   #55
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
True, you CANNOT cut the antenna on the DSM2 receivers. They have the special coax antenna.
Actually the failsafe will kick in when power drops below a safe voltage so in theory if something is damaged in the battery it could cause this.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 10-06-2010, 05:06 PM   #56
secretsg's Avatar
JR Propo Japan is moving away from DSM to FHSS for future products. I wonder if Horizon will follow suit, or stick with their DSM technology for spektrum in the states.
secretsg is offline   Reply With Quote
Old 10-06-2010, 05:12 PM   #57
Frank L's Avatar
Trader Rating: 148 (100%+)
Intimidate me....
Ya, like burning poopy in a paper bag.....
It's not that bad... lol Provided it works, that's all that really matters. All I know is I still have my M8 with specky mod and works fine. If the 3R fails or acts up, it'll be coming out for something else....
HAHAHAHA "he called the $h!T poop" HAHAHAHA
Old 10-06-2010, 05:16 PM   #58
hobdog's Avatar
Trader Rating: 19 (100%+)
so what exactly does this do? I am guessing it leaves your servos positioning where they are and it resets your trim #'s back to zero? Can someone please clarify, because if this is the case, it really is a cool feature.
Lunsford racing
Kyosho RB6
DEX408V2
Hoby
hobdog is offline   Reply With Quote
Old 10-06-2010, 05:29 PM   #59
Suspended
It resets the range of motion on the pots that actually generate the signal.
something that rarely goes out, except on Spketrum radios.
Usually if the pots lose calibration, you have bigger issues.
Storydude1 is offline   Reply With Quote
Old 10-06-2010, 05:59 PM   #60
just let u guys know that u can't cut the antenna on the dx3r receivers or have them stick out the tube and be bent cause that will cause problems with them i have one for over a year and never had a glitch or anything and i have only used spektrum radios since they came out starting with the dx2 and the dx2.0 and now the dx3r , if u have one of the first dx3r's they had a recall on some of them u have to check ur battery lid and see if u have the numbers that needed to back check their website out for that and they have an update about the antenna on the receiver's too ....
BigThyperST is offline   Reply With Quote
5280 Raceway - Colorado On Road RC Club (CORRC) SlamMan Colorado Racing 21404 05-01-2017 07:55 PM
Why does everyone here just give their stuff away???? OrangeDF03 R/C Items: For Sale/Trade 127 01-13-2009 08:08 PM
