Old 10-06-2010, 06:29 AM   #1
Default Is Losi 2.0 Buggy and Tryggy rear diff the same
As title says, are they the same? Is the whole case with bearings and everything the same?
Basicly, will this Buggy rear diff setup fit right into my Truggy?
If the CVD is too short, thats not a problem!
And while we are at it. How much is it really that DOES fit from one platform to another. I'm mostly concerned with what buggy stuff I can buy that will fit on a truggy. Is it only a small number of parts that does NOT fit or is it pretty much everything?
Life's like a lemon and I want my money back!
Klimpen717 is offline   Reply With Quote
Old 10-06-2010, 06:30 AM   #2
BAUSTIN's Avatar
i think they have different gear ratio's
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 10-06-2010, 06:48 AM   #3
l3asher's Avatar
The R&P gears are the only things that are not the same.
l3asher is offline   Reply With Quote
Old 10-06-2010, 08:37 AM   #4
off road god's Avatar
Only difference is the pinion gear. Buggy 13t Truggy 10t
WERKS RACING...PRO1RC...HEX CREW...BATTLEFIELD R/C...LOSI 2.0...JP PIPES...AKA,PROLINE TIRES...SPEKTRUM DX3R...JR SERVOS... PAUL CONWAY,TECHNICAL ADVISOR.
SAKURA ZERO S...NOVAK ELECTRONICS...MI SERVO...HPI PRODUCTS...FUTABA
off road god is offline   Reply With Quote
Old 10-06-2010, 09:09 AM   #5
Frank L's Avatar
Trader Rating: 148 (100%+)
The ring gears are different too. If you go to a larger pinion you have to toto a snapper ring gear. So whTs te same on both buggy and truggy are the housing, pinion coupler, bearings, diff cup, sun gears and spider gears. At least for the pic you showed above.
Old 10-06-2010, 09:26 AM   #6
I'm not familiar with all the parts name in English. What exactly is the pinion gear? Is that the one connected to the incoming CVD (from center diff?)
You have to check your typing, I have a hard time to follow you??!
What is EXACTLY do I need to change on the buggy one to fit the truggy one?
Old 10-06-2010, 09:32 AM   #7
pyromania's Avatar
Trader Rating: 18 (100%+)
The buggy diff will not work on the truggy. They use different pinion and ring gears. The truggy uses a smaller pinion gear and a different ring gear.
ie.
Buggy:
http://www.losipartshouse.com/servle...26-Rear/Detail
http://www.losipartshouse.com/servle...ff-Ring/Detail
Truggy:
http://www.losipartshouse.com/servle...Gear%2C/Detail
Jesse Carrillo
Team Driver For:
TLR | Horizon Hobby | Nitrotane | Spektrum | HandleITHobbies | 818 Designs
pyromania is offline   Reply With Quote
Old 10-06-2010, 11:46 AM   #8
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
As posted, pinion AND Ring gears are different as well as the CVD bone. It won't drop in without quite a bit of parts first.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 10-06-2010, 11:54 AM   #9
ie.
Buggy:
Truggy:
Thank you very very much, that is what I needed to know! Thank you!
