Old 10-04-2010, 07:10 AM   #1
Default losi v2 shock tower
Gonna get this tower soon. What else do i need to get to go with it? I see most people using the lower outer camber hole and the outer shock hole. Will i need new camber links? Will i need to adjust the camber links after changing the hole? I have a camber gauge but not a hudy setup station so....
Losi 8ight T 2.0 - Mugen Ninja
Mugen Eco - Tekin 1900KV RX8
Byrons 30%
Spektrum
Proline/J Concepts/AKA
bacchus is offline   Reply With Quote
Old 10-04-2010, 08:00 AM   #2
There is about 300 pages of this information in the Losi 8T 2.0 thread.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 10-04-2010, 09:13 AM   #3
Trader Rating: 19 (100%+)
In short you will need new turnbuckles on rear, the ones from buggy work, I think they are 105 mm, yes you need to readjust, I use a rpm camber guage.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 10-04-2010, 12:18 PM   #4
Is there a setup sheet everyone is using with the v2 tower? I'd like to get it on there for a race this weekend so i'm kinda pressed for time ordering everything i need. Thanks.
Byrons 30%
Spektrum
Old 10-04-2010, 12:22 PM   #5
Suspended
And with the search not working correctly, I feel for the person that has to wade through 7,337 posts to find the one with the info.
Storydude1 is offline   Reply With Quote
Old 10-04-2010, 12:34 PM   #6
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Incorrect. You don't want buggy turnbuckles. The 107mm turnbuckles from the front of the truggy are what you want.
Pretty simple really. Use a set of front turnbuckles or cut a few threads off each side of your stock turnbuckles. Run the lower outer hole on the tower and B hole on the hub. Mount the shocks in the outer #4 hole. 32.5wt oil in the rear with stock #56 pistons and 127mm of droop.
http://losi.com/ProdInfo/Files/LOSA0...akeV2Tower.pdf
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 10-04-2010, 12:40 PM   #7
8T 2.0
Starting at post 6236 -
or
http://www.losi.com/ProdInfo/Files/L...akeV2Tower.pdf
or
http://forum.losi.com/showthread.php?t=1858
I think this is as simple and straight to the point as this can get.
Old 10-04-2010, 01:01 PM   #8
Thanks guys. Exactly what I needed.
Byrons 30%
Spektrum
Losi 8ight-T 2.0 V2 rear shock tower bcarter007 Nitro Off-Road 8 01-07-2010 12:18 AM
