Old 10-03-2010, 01:38 PM   #1
gt fast's Avatar
Default tuning help
does anyone know a good setting for high and low speed needles on rc10gt motor. the .15 i know factory high speed is 2.5 turns out and low speed is 2-2.5 turns. whats a good setting for a already broke in motor.
gt fast is offline   Reply With Quote
Old 10-03-2010, 02:18 PM   #2
Trader Rating: 24 (100%+)
You tune your "engine" where it's got good out of the hole punch and good top end performance with a nice smoke trail.
Everyones tune is going to be different here dude. No one knows where you live, the elevation, what surface you run on, what type of fuel % of nitro ETC. ETC.
You might as well have said "hey, how do I fix my engine" and thats it. How is anyone supposed to know all the details?
got_nitro is offline   Reply With Quote
Old 10-03-2010, 02:33 PM   #3
NitroXray80809's Avatar
AGAIN if u search before posting u will see a thread called the tunning bible it will answer your questions in detail.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 10-03-2010, 02:35 PM   #4
blis's Avatar
Start with a 1mm throttle opening and open up the top needle and bottom needles into a rich position. Then attempt to start it at idle, only leaning the bottom until you get a good idle mix. Then lean your top needle with some throttle, then put on track and adjust the bottom for take off and the top for top speed.
there's more to it, but that's as simple as I can make it for the start.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-03-2010, 02:49 PM   #5
gt fast's Avatar
yea like heres my problem. i get it to where there is awesome bottom end, but my top end seems to be not all there. and when the tires are off the ground i can get all my top end. if gas comes out the exhaust in liquid form still im guessing i still need to lean it out right?. am i even currect with the needle that goes into the slide part of the carb, same place ball end connects to, thas the high speed right.? and the low speed is the one that actually adjust the idle
Old 10-03-2010, 03:34 PM   #6
triplebvalp's Avatar
No ... The low speed needle is the one on the ball end. The high speed needle is the one in the brass sleeve and the idle needle is a small needle on the side of the carb. This all assumes that you don't have a mid range needle which would be on the opposite end of the carb slide.
triplebvalp is offline   Reply With Quote
I need some tuning help on a OS VSPEC JoeC Offroad Nitro Engine Forum 39 09-28-2010 06:52 PM
◄I've tried everything...tuning help please► TRYMY4.0 Nitro On-Road 17 12-01-2008 07:04 AM
Savage tuning help. crash21 Monster Trucks 14 10-16-2007 02:56 PM
kyosho fw05t tuning help Roa4dbanD1t Nitro On-Road 13 03-30-2005 08:26 AM
Need tuning help. adamkerrnz Nitro On-Road 6 12-08-2004 07:27 PM
