Old 10-03-2010, 07:09 AM   #1
Trader Rating: 44 (100%+)
Default Losi Truggy turns like sh%$!!!
My Losi truggy doesn't turn for sh$#! I tried the different aluminum caster blocks, short ackerman plate and it still does not want to turn? Its terrible. I'm new at the truggy thing, so I wanted to see what some other guys set ups and tricks are? HELP!!!!!
Nitro-nutz is offline   Reply With Quote
Old 10-03-2010, 07:09 AM   #2
Smart diff help turning??????
Old 10-03-2010, 07:13 AM   #3
FOXC's Avatar
Are you using the stock set up or have you made changes? Which tires and what kind of surface at your track?
TLR 2.0EU/Novarossi+4/MLC Fuel/AKA/Fastlane Graphix
TLR 2.0T/Werks B5/MLC Fuel/AKA/Fastlane Graphix
www.rhein-main-circuit.de
FOXC is offline   Reply With Quote
Old 10-03-2010, 07:16 AM   #4
the losi truggy does not like to turn under power, it will push.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 10-03-2010, 07:19 AM   #5
Suspended
Trader Rating: 202 (96%+)
a good servo is a must in the losi truggy, makes a huge difernce in turning ability, make sure camber and toe-out is set correctly, make sure you have droop settings correct, right oil in shocks, many factors to look at for better steering, but once you get it right it will awsome!
inferno13 is offline   Reply With Quote
Old 10-03-2010, 07:30 AM   #6
Trader Rating: 24 (100%+)
got_nitro is offline   Reply With Quote
Old 10-03-2010, 07:33 AM   #7
sluggo_sx8's Avatar
Have you checked to make sure your servo saver is setup right? I find that alot of people over look this and it is a major problem . If it is set to loose the truggy/buggy will not steer worth beans.
After that is set right you can move on to setup, tire choice, droop, ride height, shock oil etc.
sluggo_sx8 is offline   Reply With Quote
Old 10-03-2010, 07:38 AM   #8
I have a 9100 JR servo and the adj hinge pin set up? I'll have to see whats its set at? I'm looking for a good all around semi beginner set-up? I've driven 2 other losi truggies and theirs steered way better than mine? It just takes turns Sooooo wide unless you can get it to spin and power around a turn? Is the stock set-up decent?
Old 10-03-2010, 07:39 AM   #9
I usually run City blocks, Grids or Double D's
Old 10-03-2010, 07:42 AM   #10
Inferno- Can you gimme some ideas of a decent set-up? Droop, shocks fluid, camber etc???? I'm totally new at the truggy thing and set-ups for it.
Sluggo- How do ya know if its too tight or too loose
Old 10-03-2010, 07:44 AM   #11
wingracer's Avatar
Trader Rating: 23 (100%+)
Glad to see this really is a legitimate thread. The title made me think it was a response to the AE sux thread that got deleted.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-03-2010, 07:45 AM   #12
No sorry I was just stating the facts. LOL it really does turn like SH%$! Hahaha
Old 10-03-2010, 07:55 AM   #13
Suspended
honestly, im really not the one to ask for advice on a perfect set-up, there are alot of guys here that can help more than i. im sure they will chime in and help you out
Old 10-03-2010, 08:00 AM   #14
losiracer78's Avatar
try a mugen
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 10-03-2010, 08:01 AM   #15
trx-1racer's Avatar
Here you go...
http://losi.com/ProdInfo/Files/LOSA0...inedBlocks.pdf
www.shortcoursehobbies.com
T-RCE Slash 4x4 - Kyosho SC-R - TLR 22
Think you're fast? Try racing in Arizona, it's like going to the Nats every weekend...
trx-1racer is offline   Reply With Quote
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
