Old 10-03-2010, 08:47 AM   #31
hdcruzer's Avatar
Most people I know that ran smart diffs dont run them anymore. Your steering problem is quite simple. Tighten your servo saver nut. Its probably loosend up and rubbing on the chassis pan. I had the same problem when I first started also. Use some locktite on the threads and that should keep it from loosening up again.....
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 10-03-2010, 08:49 AM   #32
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by got_nitro View Post
Thanks for your "HELP" and concern there GUY Everything is ironed out, I just haven't replied yet. Thats what happens when one makes multiple threads on basically the same subject.
Losi Truggy Smart Diff??????
And my apologies to you sir, I had not read your responses on another thread on the same subject to the same person..but without knowing this your response was.. ..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 10-03-2010, 08:51 AM   #33
Trader Rating: 44 (100%+)
Oasis- I'm thinking the smart diff might be the ticket for me after reading your last response. I come into turns easy and like to "hammer" my way out. I don't come into turns hard at all. Thats exactly what ya described. You run just one smart diff? Center or rear?
Nitro-nutz is offline   Reply With Quote
Old 10-03-2010, 08:55 AM   #34
neobart's Avatar
You run smart diff front and/or center never rear, I prefer to run it center only. Worked good on my track, when it was blown out and loose. Now it's smooth and grippy so I'm back to 7/5/3 in the buggy.
Clockwork Racing Engines
neobart is offline   Reply With Quote
Old 10-03-2010, 08:59 AM   #35
Yeah the outdoor track I run on is pretty loose and rough. I might try the smart center diff? My buddy has one at a pretty good price. I'm going to tear it down this week and apply all the good tips i got so far. Great site guys, thanks for all the help and advice!
Old 10-03-2010, 09:17 AM   #36
Oasis's Avatar
I always run mine in the front, I don't know why you guys want to run them in the center and rear..I look at a smart diff like a one way and use it as "one"..in the center it would unload both front and rear and didn't seem to work as well as using it in the front. Plus if your track is really tight if it's in the front it will help rotate your truggy on the brakes..it works like a one way..why are you guys running it in the center? not trying to be a smart a** just wondering..plus I race at where the factory guys race at so I know where they are using them....and a hint..it's not in the center or rear..
Old 10-03-2010, 09:29 AM   #37
Good point O?
Old 10-03-2010, 10:06 AM   #38
Frank L's Avatar
Trader Rating: 148 (100%+)
Clean the wheels then it wont smell so bad
Ohh ya and put the smart diffs in the pit box.
Old 10-03-2010, 10:10 AM   #39
Do-Over's Avatar
Originally Posted by Nitro-nutz View Post
Inferno- Can you gimme some ideas of a decent set-up? Droop, shocks fluid, camber etc???? I'm totally new at the truggy thing and set-ups for it.
Sluggo- How do ya know if its too tight or too loose
You can check your servo saver pretty easy. Just turn the wheels and hold them turned and try to turn them back by hand. If you can really easy. It's too loose and you can see where that would be a problem when trying to hold a line.
AE RC8T, Futaba,A-Main by Massive Mods, Hitec,
JConcepts, Fastraxx Hobbies, Team Terribles,
Do-Over is offline   Reply With Quote
Old 10-03-2010, 10:12 AM   #40
hdcruzer's Avatar
Frankie knows what hes talkin about. Losi Guru. You name it hes tried it...........
Coldfusion Fuel
Henchman Racing
Old 10-03-2010, 10:18 AM   #41
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Mitchell this is a completely useless thread. Put my setup on it. I know you have a copy. It'll turn. Your truggy doesn't turn because your setup is terrible. If you want, bring it up to the track sometime and I'll put my setup on it for you. Happy?
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 10-03-2010, 10:43 AM   #42
Yeah buddy. Sounds good. I PMed ya! Your the man KK
Old 10-03-2010, 05:16 PM   #43
It will turn, if u bought it used double check your set up to the std set up. The best thing i've done is I taped the set-up to wall were i work on my car everything is right in front of u for a quick reference. make sure the droop screws are in your a-arms, the guy before could have changed a-arms and forgot to put the droops screws back in, I've seen it down. and like everyone else said, ck the droop setting, ride height, rear sway bar 2.3, servo saver.
miket is offline   Reply With Quote
Old 10-03-2010, 05:22 PM   #44
I had this problem, even when the servo saver was set right. I ended up buying a new servo saver assembly and that fixed it.
Team HRC Raceway - http://www.hrcraceway.ca/
Semple is offline   Reply With Quote
Old 10-03-2010, 05:24 PM   #45
Suspended
Trader Rating: 202 (96%+)
i went to track today to play for a while, my losi truggy is set up pretty well but dint want to turn real well. found out receiver pack was no good! if all else fails......check receiver pack
inferno13 is offline   Reply With Quote
SH Z CAR easyryder Nitro Off-Road 4909 07-28-2017 08:22 AM
