Old 10-02-2010, 12:23 PM   #1
Sein's Avatar
Default Steering EPA ?
I have a rtr 8t 2.0 and with steering arm at a perfect right angle and zeroed out, on the servo, if I turn it to the right it will lock out at about 80% of travel, cool I back it down to about 76% and leave it. Problem is when I turn to the left it will not turn the wheels all the way till I am over 100% of the servo travel.
Is this normal? If I go over 100% of servo travel won't it burn out the motor?
Why does my transmitter allow me to go over 100% of servo travel?
Thanks for the help in advance!
Sein is offline   Reply With Quote
Old 10-02-2010, 12:32 PM   #2
jwm2's Avatar
As long as you aren't hearing any buzzing noise then you are fine. You can go over 100% without any issues. Although i do find it abit odd that it needs to be that high, but i guess its possible. It won't hurt the servo as long as it keeps quiet when locked in that position, its only when the servo starts to whine that you run into problems.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 10-02-2010, 01:01 PM   #3
Sein's Avatar
Right on thanks man!
Old 10-02-2010, 01:06 PM   #4
Check the link from the servo horn to the bellcrank, both should be parallel to each other to get maximum turning.
As long as the servo isn't buzzing you're fine, I set my EPA to one click below what makes the servo buzz.
Tamiya Hornet OG
Ofna Ultra MBX Pro
Associated RC8B FT
tromoly is offline   Reply With Quote
Longest Steering Servo Horn??????????? Steebo Nitro Off-Road 19 01-15-2010 02:24 AM
RC8T steering??? trap121 Electric Off-Road 17 09-05-2009 08:41 AM
Unequal steering throw Iceracer Electric On-Road 15 12-19-2006 10:31 PM
