Old 10-01-2010, 07:04 PM   #1
Default what do u guys think of side winder fuel?
Was recommended to me by LHS I'm running 30% or should I get byron ... Is it ok to switch fuels?
TL01 W/5.5T Brushless
JAMMIN X2 TRUGGY W/Force .28
wantboost is offline   Reply With Quote
Old 10-01-2010, 07:09 PM   #2
im personally a fan of Byron fuels..
rodcpierce is offline   Reply With Quote
Old 10-01-2010, 07:09 PM   #3
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
bryon. its the choice.
sidewinder-not what it once was. especially that purple crap.
R
UltegraSTI is offline   Reply With Quote
Old 10-01-2010, 07:10 PM   #4
Crazycajun322's Avatar
Byron's 25/11 all the way. You could go for 30/11 if you want, your call. Both are great. When you switch fuels, just idle half a tank, then drive the other half at a conservative speed, varying the throttle to really "re break in" the engine to the new fuel. Then you'll be ready to go!
If you have a traxxas and its not broken, then you must not be running it!
Slash 4x4-Proline Calibers, JConcepts Dare body
Kyosho Inferno 7.5 Sport-Spektrum Dx3e, Byron's 25/11, Proline Crimefighters
Crazycajun322 is offline   Reply With Quote
Old 10-01-2010, 07:11 PM   #5
I bought the red stuff... How come people don't like it
Old 10-01-2010, 07:15 PM   #6
the problem with fuels which have a heavy dye(red, blue, purple) is that the dye can burn into a gunky mess in the sleeve and scar the sleeve and/or piston. byrons has a thin orange dye which burns very clean.
Old 10-01-2010, 07:17 PM   #7
One gallon of the red stuff wont hurt it, but after about 2-4 gallons, you might run into some problems. Dont worry about it for now, burn what you have, then i would strongly endorse byron's.
Old 10-01-2010, 07:23 PM   #8
blktransam's Avatar
Trader Rating: 59 (100%+)
I ran the red stuff for 2 years with zero issues..but I am one of them people that opens up my engines every gallon or two to check everything out and clean the carbon off the top of my pistons...never had any issues with the red stuff, once the purple stuff came out I jumped to nitrotane again no issues with tuning...
I am from IOWA which is where byrons is made I loved the original yellow fuel but hated the gen2 when it first came out...have not tried it since been a couple years...
-Ryan Klemme
NemoRacingUSA.com,Beta tires,Agama, Triton Engines, Rocket Graphics, Byron Fuels, RcRenew, Major Art & Hobby, BuKu Products,
Midwest team manager for Nemoracingusa
Owner of Midwest Rc Tour
blktransam is offline   Reply With Quote
Old 10-01-2010, 07:26 PM   #9
2fst2c's Avatar
Trader Rating: 114 (100%+)
I didn't know it was dye. I was told it was the color of the oil blend they use with the after-run oil built in.
I've ran the World's Blend 30% for the last 2 years. I've got motors that have over 3 gallons on them and they still look brand new. What kind of problems should I look for in the next gallon?
2fst2c is offline   Reply With Quote
Old 10-01-2010, 07:27 PM   #10
Shane Racer's Avatar
The purple "Team Strike" is very good fuel. Never had the dye do anything to my sleeves or pistons. Your going to get different answers from everyone. The best thing you could do is try it yourself.
KYOSHO AMERICA-Novarossi-M2C racing-Competition Heat-Grandview Hobbies-Fastraxx Hobbies-TKO-Clockwork-The Ohio RC Factory
Shane Racer is offline   Reply With Quote
Old 10-01-2010, 07:29 PM   #11
I've ran byrons and Amain fuel more then any other fuel I've ran. I recently switched to the red sidewinder because Byron's is hard for me to get. The biggest difference I have noticed is that sidewinder seems to run cooler, but there is much, much less smoke. My engine seems to run the same at 210 with the sidewinder as it did at 235 with Amain, and about 245 with the Byron's.
I know temps mean little, but that is the only thing I can use for an example.
I'm going back to Amain or Byron's the next chance I get. The lack of smoke with the sidewinder makes me a little nervous.
Keep in mind though I've only been into nitro since about march of this year. So I'm not near the most experienced person with fuels. I like the thread though becasue I was wondering the same thing. For me though I think Amain has been my favorite fuel so far. It seems like it's easier to tune then the Byrons and I seem to get a little better run times because I can lean it out more.
bevofrancis is offline   Reply With Quote
Old 10-01-2010, 07:31 PM   #12
We switched from Byron's to Strike purple and have better run times and cooler temps. We have went thru almost 11 gallons since late last winter and zero issues. One motor is a V-spec and other is Ninja JX. The V-spec has the majority of the fuel thru it.
Buy a quart and try it for yourself. Then compare.
Randy
RandyJones is offline   Reply With Quote
Old 10-01-2010, 07:33 PM   #13
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
The new Strike Team (Purple Stuff) is by far better than the older stuff. Engine runs cooler, Better all around performance. Great run time as well. If it was not good fuel, Robbers, Maifield, Cavaleri, and so on would not run it. Its an awesome fuel. Byrons is good too, But you cannot beat Sidewinder!
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 10-01-2010, 07:35 PM   #14
Suspended
I make my own, but I'll say Oil content is more important to engine life than what brand.
All of the modern RC fuels are good, some better than others and some outstanding(like my homebrew LOL)
As long as it's 10% oil minimum or up to 15% max, your engine will thank you.
Higher oil content may be harder to tune for, may increase temps and may frustrate you with tuning(I've made batches that it screwed up on and made it like 20%. Funny to pass people on the straight puffing like a freighttrain and screaming lean LOL)
Best advice on a new fuel?
Buy 2 Qts and try it. If you like it, buy gallons next time.
Storydude1 is offline   Reply With Quote
Old 10-01-2010, 07:45 PM   #15
I love the Purple Team Strike fuel. Yes it does give better run times and cooler engine temps, NO sacrifice in power at all, I actually think I have more over all than all the fuels I have ran in the past. My only problem with the fuel I have found is using it with motors with 5+ gallons that used other fuel won't tune correctly, and the fuel is a lil more pricy, but it's deff worth getting if it's one of ur choices. Byrons is good, Nitro Juice is ok, JACs Fuel (local guy) good, Sidewinder Worlds Blend good.
Andy
TLR 22 Rear & Mid
Superior Hobbies - RC King - Tyrant RC Graphics
Holeshot Raceway www.HSRaceway.com
SCRC Spacecoast RC www.spacecoastrc.com
02maxima18 is offline   Reply With Quote
