Old 09-29-2010, 08:55 PM   #16
auxie22's Avatar
Default Wow!
Thanks a heap for all your suggestions, I think you guys are right I will get the mp9SE. I have a Vspec already but need parts to fix it (Apparently the guy thrashed it while running it on a bench) got it for $20 and all i have to replace is the con rod piston and sleeve everything else is good I might still buy a new one and build the old one up slowly. I want those specific servos because I can run a 7.4v lipo and they each have high torque and high speed at 7.4v. What do you guys suggest for an exhaust? JP-3, Dyno 053, T-2050SC, T-2060SC. I have heard all of those are really quite good. I am thinking the one of the os pipes because mark pavidis runs one with a vspec engine. I have budgeted for the T-2060SC. Thanks for all your help, I will let you know how it all goes.
Schumacher Mi1 | Schumacher Mi5 | Team Orion R10 PRO | Team Orion VST Pro 17.5 | Team Orion VST Pro 8.5 | KO Propo EX-10
auxie22 is offline   Reply With Quote
Old 09-29-2010, 08:58 PM   #17
cdc
Hitec 7955 servos can run lipo to.
Kyosho MP9 TKI4 - OS SPEED - KO RSx Servos - Futaba 4PX
cdc is offline   Reply With Quote
Old 09-29-2010, 08:59 PM   #18
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
y buy an rtr when ur ganna rip it all apart and change parts when by the time its all said and done you can buy a mp9? MAYBE! lol no rtr's please.
Xray XB4 | Ko-Propo | Savox | Hobbywing | SpeedPassion | JC |
Kyosho RB6 | Ko-Propo | Futaba | Turnigy | Orion | JC |
AE T4.2 | Ko-Propo | Savox | Turnigy | ProTek | JC |
NitroXray80809 is offline   Reply With Quote
Old 09-29-2010, 11:04 PM   #19
auxie22's Avatar
Default 7955tg
@cdc what are the specs of the 7955tg at 7.4v?
I have had a look around and all I get is specs for 6v.
Old 09-29-2010, 11:29 PM   #20
jmaxey51's Avatar
better than the 7950 or 7940 specs.
and on the pipes you can save a ton and get a RE10 or RE11 pipe. RE10 is almost the exact pipe as the 2060 (cant tell a difference) and the RE11 is the same as the 2050 (no one can tell the difference.) dont get the JP3 or 053, they kinda suck the fuel when combined with Vspec.
Jonathan Maxey - Mugen Seiki USA, Alpha-Plus Engines, O'donnell Fuel Team, Sweep Racing USA, M2C Racing, Airtronics, TritonRC.com, RC Renew, 4C Hobby Supply
Mugen MBX7 / Alpha-Plus Engine / Airtronics M11x
Mugen MBX6T / Alpha-Plus Engine / Airtronics M11x
Mugen MBX7 Eco / LRP / Airtronics M11x
jmaxey51 is offline   Reply With Quote
Old 09-30-2010, 10:36 AM   #21
Trader Rating: 30 (100%+)
re11 has round header instead of d header like 2050 so if you get the re11 need to find a d header the difference is in the top end
jewn_beef is offline   Reply With Quote
Old 09-30-2010, 11:03 AM   #22
more than enough for any buggy or truggy.
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 09-30-2010, 11:20 AM   #23
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Over 300 oz of torque. More than you'll ever need... and I have BEAT on a 5955 and 7955 for 2 years now, without a whimper.
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 09-30-2010, 11:33 AM   #24
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Same specs as the 7954. They are the same servo with the exception of the gears. 7955 uses titanium gears and the 7954 uses steel gears to cut costs. 7955 is a better servo.
RE11 is the same yeah, RE10 is not. They are close as you say, but you can tell a difference. There is a physical difference in the measurements of the pipes and a difference in how they perform on the track. RE10 is an awesome pipe though. Not quite as smooth as the 2060 and not quite as good on fuel from what I've seen.
The 7950 has much better specs than the 7955 on 7.4v. 7955 is an awesome servo, but the 7950 is better.
The L shaped double bend header that comes with the 2050 actually provides more bottom end vs. the C shaped smooth round headers.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 09-30-2010, 11:38 AM   #25
cdc
The Hitec 7950th is a better servo than the 7955.
Old 09-30-2010, 11:57 AM   #26
Frank L's Avatar
Trader Rating: 148 (100%+)
I would go with the hitec 7940/7950 combo they are designated hv servos and you can't beat hitec customer service. Then use the 2060 pipe it was made for the vspec. The 053 will cut the top off and idk about the losi pipes.
Old 09-30-2010, 12:26 PM   #27
The new 7945 looks sweet too! I'm thinking that will be my next throttle servo. You can't beat the 7950 for steering. Massive torque and plenty of speed for me. I agree about the 2060. Awesome pipe!
-Koby Kubrin-
Old 10-02-2010, 11:03 PM   #28
auxie22's Avatar
Default Thanks
I'm getting the 7940 and 7950 combo and yeah I will get the 2060
