How to keep a throttle servo alive in a Losi 8 T/B 2.0 ?
LOSI 8 2.0 truggy & buggy/How to keep a throttle servo ALIVE ?
Losi 8B 2.0 / dead JR 9100HVT 3 races
Losi 8T 2.0/ dead JR 9100HVS 5 Races
Losi 8T 2.0/ dead Hitec 7940TH 6 races
All electrical not gear related failer?
From what I have seen JR's don't last worth a crap no matter waht you have them in.. Also the 7940's seem to have there fair share of failures deffinetaly not normal for Hitec, go and buy yourself a Hitec 7945.. Make sure you ahve your carb positioned like recomended in the manual and have the linkage level..
lol, i dont know whats up with the burned up throttle servos i been running my futaba diginal servo and did trim the throttle spring so it was less stressing and i run rubber grummets under the servo and a radio tray sitffner .
and im not perfect at setting linkages up im talking about my 1.0 t by the way.
if you, have a 2.0 than get the one piece alum diff mount i tryed it on my and i couldnt get it to work at all !
so im having to rotate the carb so the boot doesnt rub the diff mount.
i would blow one servo every 5 tanks on my 8ightB and they were JR590 servos. once i did tons of research i followed the setup to the T and got the kingheads servo tray stiffener and i have a cheapo jr270 servo and have not blown one in over a gallon of fuel. also i did the dual o-rings under the rear of the battery on the servo tray
Suspended
Just follow this:
http://losi.com/ProdInfo/Files/LOS_T...ke_Linkage.pdf
And make sure your carb it not binding.
u may have to trim the side guards. if the servo is hitting the guards they will fry. i have been running the same servos in both buggy and truggy for the past 2 yrs with no issues. ed if u wanna take a look at what i'm talking about i will b at the hut on sunday. i will b driving both buggy and truggy blue and pink bodies.
