Old 09-28-2010, 11:00 AM   #16
I wonder if this would get the tire foam off my on-road pipes
Losi 8T 2.0 - Novarossi P5 Modded - JR 9100HVS' - Odonnell Fuel -
Mugen MBX6 - Novarossi +4 Modded - Hitec 7940TH's - Hudy Tools
Andy Z is offline   Reply With Quote
Old 09-30-2010, 07:09 AM   #17
Be careful with antifreeze with anything except a crock pot . My buddy put on stove had 6 foot flames, if not for 10' ceilings house would of burnt down. I didn't know it would burn at all.
MBX6/Techno MMM-2200/MBX6-Nova Plus-4C/ MBX5R-Werks B7
MBX5R-Nova Plus-4C/Mini Inferno brushless/ 14yr Daughter's rigs.
Losi XXXNT Phantom/Few MBX5Pro spares
MST-1 Nova/MST-1 soon to be brushless
/About a dozen Nitro boats .12-.90/
153stars is offline   Reply With Quote
Old 09-30-2010, 07:20 AM   #18
I will probably try it with a hotplate outside on low, hopefully I finish the day with my eyebrows
Old 09-30-2010, 09:28 AM   #19
I'm sure he got it over 400f before it flashed
Don't forget to protect from your pets as well it turns to formaldehyde in bodies that ingest, poison no antidote.
Old 09-30-2010, 09:43 AM   #20
l3asher's Avatar
Originally Posted by bigjayjay1 View Post
im going to try a hot plate work using a normal pot set at a low temp?
Spend the 10 bucks on a cheap-o crock pot.
l3asher is offline   Reply With Quote
Old 09-30-2010, 12:23 PM   #21
bigjayjay1's Avatar
Trader Rating: 86 (99%+)
yeah after the fire comment your are right Walmart here i come Do you guys cover a store or dump and add when its needed again?
TEAM: SERPENT AMERICA DRIVER -ADVANTAGE RACING PRODUCTS-COMPETITION HEAT INC - HOBBYPRO, VPPRO - BCE-
Serpent: 811N, 811T, 811E
bigjayjay1 is offline   Reply With Quote
Old 09-30-2010, 12:47 PM   #22
DezSlash's Avatar
I put it back one the bottle with a fnnel and save till I need it again.
Companies I support
Hot Bodies*Futaba*Novarossi*JConcepts*Hitec*Upgrade Rc*Kalgard*Sidewinder Fuel*Dialed
Arcor Raceway
DezSlash is offline   Reply With Quote
Old 09-30-2010, 01:09 PM   #23
l3asher's Avatar
I bring mine to a buddy at a local oil change place.
Old 09-30-2010, 02:02 PM   #24
Default the best way, hands down.
Go to an auto parts store and buy a gallon can of Gunk carb/parts cleaner. it comes with a basket inside. I'm not sure of the cost. Disassemble the pipe and header. Put them in the basket and drop into the can. Let it set over night. Next day, rinse off with water. Pipe is perfectly clean. It is part of my regular maintenance. Works perfect, very little effort. Watch how much build up comes from inside the pipe when you rinse it. I usually pull it out of the can, spray it inside and out with Simple Green, then rinse it good in the garage sink. There is no other way. Gallon will last forever. You can do this to the oldest, nastiest pipe, and it will come clean.
MIKE WELLS is offline   Reply With Quote
Old 09-30-2010, 04:45 PM   #25
dishsoap's Avatar
While on this note. What do you use to plug the pipe and how much water do you put in it when you put it into the freezer to get the dents out. How long do you leave it in.
HobbyTown USA Tucson!!! HobbyTown USA SRS!!!!
dishsoap is offline   Reply With Quote
