Old 09-27-2010, 01:12 PM   #1
Unhappy Car running when no throttle given!
I just got a new buggy with a 1.75l engine. But when I began with the break-in procedure, its wheels spun wildly even when I hadn't pressed the throttle trigger. My methanol : castor oil ratio is 5:1.
The buggy runs a few metres when kept on ground and then halts abruptly (maybe an indication that mixture is rich). I even tried decreasing the idling speed by turning the idle screw...didn't work.
nvpF1crazy is offline   Reply With Quote
Old 09-27-2010, 01:52 PM   #2
Sounds like a lean low speed needle. the needle by the carb that is on the slide body...turn it counter clockwise 1/4 a turn and try it again.
Either that or the clutch is engaged when it should not be.
Who makes the engine and what is the model number? Maybe you can try going back to factory default settings and try it.
Kyosho V-One RRR - JP Modified Mugen X12 - GQ Racing Tires - Futaba servos - KO Helios w/Spektrum Pro - Maxy's Fuel
Losi 8ight 2.0 RTR for fun times
Dredd is offline   Reply With Quote
Old 09-27-2010, 01:52 PM   #3
BAUSTIN's Avatar
or possibly a clutch issue......bearing or spring?
Billy Austin
www.Code3RC.com
Elevation Sports
BAUSTIN is offline   Reply With Quote
Old 09-27-2010, 02:06 PM   #4
jwm2's Avatar
I'd check the trim on the radio as well. With the engine shut off, find out whats causing the throttle to open up without input from the radio.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-27-2010, 04:13 PM   #5
pitpop's Avatar
this problem is too broad, you need a professional at your local track to look at it, or someone at a hobby shop could probably tell you what's wrong in a few minutes...
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
Old 09-27-2010, 05:52 PM   #6
True, without seeing every part we cannot diagnose it here. For all we know it could be linkage or servo settings.
Old 09-28-2010, 04:47 AM   #7
I have 2 trim dials on my control: steering and throttle. How do I check them?
Old 09-28-2010, 04:54 AM   #8
turn on radio/car electrics/ engine off
steering trim..adjust till wheels are straight ahead
throttle trim...remove air cleaner and throttle slide should be in the closed position with a gap of no more than .5-1.0 mm
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 09-28-2010, 11:18 AM   #9
road-runner's Avatar
Wink Cluth Bearings
Try that it happened to mine
road-runner is offline   Reply With Quote
Old 09-28-2010, 11:28 AM   #10
jwm2's Avatar
Depends on which radio you have. Most ready-to-run radios are pretty cheap and don't have anything other than the trim knobs on the outside of the remote. Make sure they are centered and then remove the air filter and check the gap. If its more than 1mm then its not closing all the way and you need to figure out what is causing that to happen.
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 11:12 AM
MINI Z beebop Indonesia Racing 7572 01-24-2017 09:16 AM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
Z-Car 1/8 Buggy E-conversion GSMnow Electric Off-Road 96 12-14-2010 04:32 PM
Transitioning from nitro. What should my first car be? sokar Electric Off-Road 42 08-05-2009 07:12 PM
