Old 09-26-2010, 03:34 PM   #1
gt fast's Avatar
Default cvd or dogbone
so i guess my rc10gt is the rtr version which i was unaware of at the time i bought it from a friend. now i bought some wheels the other day for the rear, and the axle would not fit into the wheel. the wheel said its for rc10gt so could it be the rtr is diff from the other rc10gt's. and if so what could i do. also what is the differance between the stock dogbone axles and the cvd axles i think there called. the guy at the local hobby shop couldnt find a bearing for my truck either so what could be going on with my axles.
gt fast is offline   Reply With Quote
Old 09-26-2010, 03:56 PM   #2
Trader Rating: 24 (100%+)
Dog bones, cups-n-bones, bones-n-cups, CVD's = same thing.
got_nitro is offline   Reply With Quote
Old 09-26-2010, 04:32 PM   #3
tmaxx26power's Avatar
Trader Rating: 39 (100%+)
take pics and post of the truck and then the axles and we will help you figure out what you got
Kyosho RB6 Stock Buggy
Kyosho ZX6 Mod 4wd Buggy
Kyosho SC6 Pro2
tmaxx26power is offline   Reply With Quote
Old 09-26-2010, 05:43 PM   #4
Suspended
Ummm, No.
CVD's=captured ball-type joints.
Dogbones=2 seperate parts.
U-joints=Captured center block joints.
And the RC-10 GT has 2 different sizes of rear axles.
Storydude1 is offline   Reply With Quote
Old 09-26-2010, 07:25 PM   #5
Originally Posted by Storydude1 View Post
Ummm, No.
Ummm yeah. They are not sliders...
CVD= Constant velocity drive shafts, they do have a cup and bone....
Dog bones need cups, No need to get all scientifically technical when essentially they are the same thing.
Old 09-26-2010, 08:24 PM   #6
gt fast's Avatar
yea ive heard that the cvd doesnt bind during long suspension travel, and seeing as my car is rarly on the ground i might want to go that route. i live in the desert so id say for every 5 feet it goes it lifts off the ground from the uneven surface. in that sence the dogbones fall out of the binding on the transfer case.
Old 09-26-2010, 08:37 PM   #7
The cvd axlesfor the gt are 3/16 I think and the rtr dog bone axles are 1/4 inch and each needs a rear hub and different bearing to work. and the rear wheels take a different axle pin because of this. you have a rtr and it sounds like wheels for the gt .
** Scott's Hooker Service** Craftworld and Action Hobbies**Craco Cryogenics** Hotbodies D8T **Fusion X Engines** Byron Fuels ** Hitec Servos ** Spectrum **AKA Tires**
nothin special is offline   Reply With Quote
Old 09-26-2010, 09:05 PM   #8
Suspended
A cup and a bone held together with a pin, essentially making them one unit.
Not separate parts like a dogbone.
Not even close to the same thing.
Ask your LHS "I need dogbones for am X1" And watch them hand you Dogbones. Ask them for "universals for an X1" and watch them hand you something completely different.
Are they the same thing?
And in case you haven't been reading, the CVD on a 10GT are DIFFERENT SIZES than the RTR Stubaxles. So they are not the same thing.
Old 09-27-2010, 06:54 PM   #9
drewmugx5t's Avatar
Trader Rating: 21 (96%+)
I'm betting you got quick change wheels. It uses a different axle and has a larger hole in the middle with a hex on the inside. The normal wheels have a smaller hole with a big + on the inside.
drewmugx5t is offline   Reply With Quote
Old 09-27-2010, 08:08 PM   #10
gt fast's Avatar
thank you to all you are all helping. the wheels said for the rc10gt, but yes my axle coming out of the hub was just a little wider then the wheel. i do have dogbones, both sides of the axle are the same not like cvd where one said is on a pivot. and from what ive heard and read the rtr does have the other size bearing for the rear hub so thanks for clearing that up for me. my wheels do not have the hex( im assuming the hex is somthing like the ones traxxas uses). my axle come out of the hub and is held in by that pain in the butt axle pin. then the wheel itself goes on and sits on the pin, no hex.
SC10 which differential gear or ball??? cliffhanger Electric Off-Road 88 08-23-2014 02:46 PM
HPI BAJA OR KM BAJA 1/5 SCALE CHAT ROOM baja 5B Malaysian R/C Racers 5208 05-06-2014 03:53 AM
Losi Constant Velocity Drive (LCD) vs MIP CVD John Stranahan Electric On-Road 263 01-24-2010 11:51 AM
CVD or Universal, which is better? jamiekulhanek Electric Off-Road 15 11-04-2004 06:23 PM
