Old 09-20-2010, 04:13 PM   #1
jwm2's Avatar
Default 8T 2.0 Shock/Ride Height
I was just setting the ride height on my 8ight 2.0 truggy and noticed to get the rear 40-42mm high that the adjustment nuts have to be nearly all the way at the bottom of the threaded shock body. I mean only a couple threads are left (2-4) on the shock body when adjusted to where it needs to be. Is this normal? Its not that way on my buggy.
Also i noticed one side of the truggy or buggy sits just a shade lower than the other. Should i adjust the shocks so the chassis is even? It seems like one side needs to be several threads higher than the other to compinsate the difference.
I'm going by adam drakes setup sheets and the various setup sheets off the losi website as a reference. I just want a decent baseline to start my tuning on various tracks i plan on visiting over the fall and winter as racing moves indoors in this area. So i figure if i start with the standard setups and deviate from that as nessissary, it'll give me a good baseline to get me headed in the right direction.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-20-2010, 04:34 PM   #2
losi_racer's Avatar
Trader Rating: 25 (100%+)
if both adjustment nuts are even on the shock bodys and one side is higher then you most likely have a bent hinge pin, also your a arms could be warped.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 09-20-2010, 04:49 PM   #3
jwm2's Avatar
I just checked the pins when i rebuilt the diffs this last week, they seemed fine. I don't think the a-arms are warped, but i'll have to double check. What do you think about the nuts being at the bottom of the threads to get the right ride height? Thanks
Old 09-20-2010, 04:52 PM   #4
losi_racer's Avatar
thats no big deal, ride height will be affected by numerous different things which will make you raise and lower the preload on the springs
Old 09-20-2010, 04:53 PM   #5
CJ Weaver's Avatar
Send a message via AIM to CJ Weaver
All springs aren't made the same, every spring is different and some are more extreme than others. Therefore, the spring collars aren't always going to be in the exact same spots, but they should be relatively close. If the weight is distributed evenly and the amount of tension is the same on all four corners, then run it.
RCAmerica | Team Xray | Hudy | JConcepts | Kal-Gard | KO Propo
Novarossi | Fine Line Design | ProTek RC | Byron Fuels | Team Tekin
Vinyl Graphics Unlimited | A-Main Hobbies | A-B Charles Hobby Shop
CJ Weaver is offline   Reply With Quote
Old 09-20-2010, 05:02 PM   #6
jwm2's Avatar
Ok cool, i'm wondering if the reason it was off balance is due to not having fuel in the tanks. They both seemed to be leaning twords the side without the fuel tank. I wonder if i add fuel if that levels it back out. Its just a hair higher on 1 side of both my buggy and truggy. I mean literally its less than .1-.2mm, which is probably not noticable by most people but i've been trained to notice even the smallest of differences over the years due to various jobs and tasks i've completed.
Old 09-20-2010, 05:03 PM   #7
jwm2's Avatar
In fact if i posted a picture i can guarantee noone would spot the difference, its really that small of a difference. Guess i was being too picky, no biggie though
Old 09-20-2010, 05:05 PM   #8
Suspended
Trader Rating: 202 (96%+)
+1, also may have a weak spring.
inferno13 is offline   Reply With Quote
Old 09-20-2010, 05:39 PM   #9
tc5 man's Avatar
inferno you have a pm by me.
tc5 man is online now   Reply With Quote
Old 09-20-2010, 06:03 PM   #10
jwm2's Avatar
I do have some new springs i might be able to throw on it. I'll give that a try. I wasn't even thinking the spring could be worn, but its worth a look.
Old 09-21-2010, 02:13 AM   #11
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
was the car full of fuel?
the weight balence of the truggy isnt perfect. the weight of the fuel can balence out the chassis
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 09-21-2010, 07:58 AM   #12
jwm2's Avatar
I filled em both with fuel and that seemed to straighten it out for the most part. I didn't think fuel would make that much of a difference, but i guess it does. I also found my ride height gauge wasn't 100% correct on its readings. I used my digital calipers to find out exactly where i needed to be and it was about .5 mm - .8mm off each time on the high side.
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
Losi 8ight T 2.0, Futaba 3PKS, Hyperion, AKA, Novarossi, Hudy, AMB, tools looneytune R/C Items: For Sale/Trade 27 01-04-2010 04:35 PM
8T 2.0 Setup sheets....post here jzemaxx Nitro Off-Road 31 09-13-2009 03:42 AM
