Old 09-20-2010, 10:09 AM   #16
lewis666's Avatar
Send a message via MSN to lewis666
i like the concept of your balancer looks like a success.
i tried ine similar but holding the hud and it did not work and it was a disaster so my dad came up with this idea. i would prefer to have the enjoyment of making one instead of buying one off the shelf, and i saved about 35 so it is win win!!
many thanks
lewis
Durango DEX410R, BCE Losi 8ight 1.5 (radical 621t), Durango DESC410R on the way!
radical engines- www.gotnitroonline.com
Got nitro team driver
lewis666 is offline   Reply With Quote
Old 09-20-2010, 10:23 AM   #17
jwm2's Avatar
Yeah it spins nice and freely, in fact with just a slight push the wheel seemingly spins forever. I'm quite shocked at how well an old bearing works without any lubrication what-so-ever. Its also nice cuz i can attach it to the edge of my work bench where ever i need it as space on my bench is at a premium these days I'm kind of shocked how off balance some of the wheels were. I had buggy wheels that needed quite a bit of clay and truggy wheels which needed hardly any. Nice tool to have though, its just one more thing that will help me maintain better control over my rigs and get all the speed possible out of them.
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-20-2010, 06:55 PM   #18
rotarynut's Avatar
Trader Rating: 30 (100%+)
Originally Posted by jwm2 View Post
Its a nice balancer. As long as it does what you hoped it would do, i'd say its a success. One of the things i mulled over for about an hour was how to make it one sided, so the other end was not closed mainly just for easeness of use. I like the fact i can pull the rod out of the bearing slap a new wheel on and put it back within just a few seconds. My only gripe with my unit is the bearing tends to fall out when you pull the rod through when taking the wheel off. I tried all sorts of things to prevent the bearing from coming out but each time i was left with a bearing that wasn't as free as just having it sit in there without anything holding it in. I'm sure i could make some kind of shield if i wanted to, but for now it works great the way i have it.
Slide some rubber o-rings (smaller than the shaft) on either side of the bearings, they won't put any kind of bind on the bearing and it'll be easy enough remove when needed
Robert S.
CEN Matrix R2 1/8 Buggy, Novarossi Toronero H.E.S.Tuned 9901/41021, Hitec HS-7955TG/5625M
Losi 8ight-T 2.0,BCE chassis, Novarossi 21-7 FMS H.E.S. Tuned 2084SS/41021
Hitec HS-7955TG/5645MG - Stickman Batteries -Airtronics M11x
Traxxas Summit 1/10 on Gens Ace 2S lipos 5000mah
rotarynut is offline   Reply With Quote
Old 09-20-2010, 07:11 PM   #19
jwm2's Avatar
Yeah i don't have any on hand so i'll need to grab some. Not in a big rush though, i have all my tires balanced now
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 04:22 PM
wheel balancer help! lewis666 Nitro Off-Road 45 05-27-2011 04:38 PM
My Homemade tire balancer....check it out!!!! JOEHULL Nitro Off-Road 66 10-12-2010 09:19 PM
