Old 09-19-2010, 05:55 PM   #1
Default 8ight T flywheel Dia?
I'm trying to get a clutch together for my sons Jammin X2 CRT with a werks B5 (thanks to RayA for the free motor). Anyways, I'm thinking about going with a Losi 8ieght T clutch and would like to know what the diameter of the flywheel is. Apparently the stock flywheel in an X2 is 35mm, so I'm assuming that I would need something around that size so I don't have problems engaging the starter box wheel.
Glenwyatt is offline   Reply With Quote
Old 09-19-2010, 05:57 PM   #2
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
34mm
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 09-19-2010, 05:59 PM   #3
Suspended
Trader Rating: 202 (96%+)
i dont think a losi clutch will work for you, losi clutch is a little longer than a regular clutch, clutchbell may hit gas tank, or bell will be to close to spur, not 100% sure, someone will let you know forsure shortly im sure!
inferno13 is offline   Reply With Quote
Old 09-24-2010, 05:16 PM   #4
Isn't the length of the clutch end of the crank shaft standardized?
Does anyone know this if this setup won't work with any certainty?
Help me out please!!!
Old 09-24-2010, 08:41 PM   #5
Its only the losi clutch bell thats 2mm longer, the clutch itself is the same width as most other clutch setups.
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 09-24-2010, 08:56 PM   #6
Suspended
i dont beleive this is correct, the bell is longer, because the clutch is also.
Old 09-24-2010, 09:55 PM   #7
Trader Rating: 35 (100%+)
I have a losi flywheel you can have if you wanna see if it works?
Hobbs263 is offline   Reply With Quote
Old 09-25-2010, 08:01 AM   #8
Thanks for the offer...that's really generous.
I'm thinking that I would need the whole setup though to see if this would work.
The only reason I ask about this is that from a pure design standpoint I like the losi design better than the OFNA.
There has to be someone out there who done this or someone who's got an X2 and a losi clutch laying around who can give it a shot...PLEASE....THANKS.
Again, thanks for the offer.
