Old 09-18-2010, 07:05 PM   #1
Crazycajun322's Avatar
Default Engine Issues please help
So I went to fire up my inferno today, and it started fine, but after removing the glow starter after a minute of idling, it died. I repeated this several times, but it kept dying after I removed the glow starter. I finally resorted to hitting the throttle all out while removing the starter to build up enough heat to keep the damn thing running, but normally it keeps idling just fine after I remove the starter. I changed spark plugs, same problem. Also, the tune that it has held for 10 tanks now is suddenly making the engine run hot. I was running it in the 220s, but it spiked at 270 today on the same tune.
I am running Byron's 25/11
If you have a traxxas and its not broken, then you must not be running it!
Slash 4x4-Proline Calibers, JConcepts Dare body
Kyosho Inferno 7.5 Sport-Spektrum Dx3e, Byron's 25/11, Proline Crimefighters
Crazycajun322 is offline   Reply With Quote
Old 09-18-2010, 07:25 PM   #2
Suspended
Trader Rating: 202 (96%+)
what engine you have? may be a air leak or in need of hotter plug. how much fuel has been run through this engine?
inferno13 is offline   Reply With Quote
Old 09-18-2010, 07:30 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
it could be a dead glow starter. he mentioned he revved it up
"I finally resorted to hitting the throttle all out while removing the starter to build up enough heat to keep the damn thing running"
FYI your glow plug runs off the initial glow it gets from the starter,. if your starter is dead or weak it would be like running a colder plug than what it actually is.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 09-18-2010, 07:32 PM   #4
its the stock kyosho gx21 engine. Put a little over a gallon through it. Took the head off, looked fine. Removed the exhaust pipe, that was fine. The only difference is that I put a fuel filter in recently, but I dont think that would have anything to do with compression or ignition other than cleaner fuel.
Old 09-18-2010, 07:33 PM   #5
I charged the glow starter too, same problem. Ill do some more tests tomorrow though.
Old 09-18-2010, 07:35 PM   #6
hey joe, are you by chance related to Mike Alessi? I was watching a show about him on fuelTV the other day
Old 09-18-2010, 07:36 PM   #7
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
dont know where you live but are you shure its not just weather change that its leaning out?
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 09-18-2010, 07:38 PM   #8
I live in Virginia. Its been 85 and sunny all week. Doubt its having that much of an effect.
Old 09-18-2010, 07:41 PM   #9
Do-Over's Avatar
I fuel filter is just another place for an air leak I would look at that filter really close as they can easily have leaks and that sounds like what this is!
AE RC8T, Futaba,A-Main by Massive Mods, Hitec,
JConcepts, Fastraxx Hobbies, Team Terribles,
Do-Over is offline   Reply With Quote
Old 09-18-2010, 07:44 PM   #10
Ya that would explain it. Ill put the old fuel lines in tomorrow and see how it runs. My old cranky neighbors are starting to get annoyed by the noise....maybe I should invite my friends over with their nitros.
Old 09-18-2010, 07:44 PM   #11
jpalessi's Avatar
hey, no im not related to Mike, but i'm buddies with his brother Jeff who is also a pro MX guy.
I would pull that fuel filter off it may have an air leak causing your problems. Good luck!
Joe Alessi
www.Lucky7RC.com
Old 09-18-2010, 07:50 PM   #12
recently had the same problem with my ninja and it turned out to be the front bearing leaking. put in a tko ceramic and problem solved.
A frend of mine had the same problem a while back and we found out he had lubed his air filter with shock oil.
CTEKTOOL is offline   Reply With Quote
Old 09-18-2010, 07:51 PM   #13
Do-Over's Avatar
I've never run the fuel filter cause I know people who have had them leak I'm curious tho... could you seal them with lucky's J? Never had to seal an engine so far... lucky me. (Pun intended)
Old 09-18-2010, 07:54 PM   #14
Suspended
make sure your head bolts are nice and tight, as for fuel filter, just throw it in the garbage. try a hot plug and make sure your glow ignighter is charged fully, let it warm up a touch before removing ignighter. make sure idle gap is set to spec. and set back to factory settings and start over, just be patient with it. goodluck!!!! hope we all have helped!!
Old 09-18-2010, 08:31 PM   #15
jmackani's Avatar
I would check your needle settings. The last two weeks here in PA most of us have had to richen up the engines with the drop in humidity and temperatures. Fall seems to have come early here. Although making it richer is only going to solve your temperature and not necessarily it not wanting to run which would probably make it worse.
jmackani is offline   Reply With Quote
Stuck throttle! Please help! Nikzilla Nitro Off-Road 32 07-05-2009 03:52 PM
Buggy needs engine, please help trlprk Nitro Off-Road 21 04-06-2009 08:06 PM
Engine Flame out issues. Please Help. rodneybarrett Onroad Nitro Engine Zone 24 07-04-2004 08:37 PM
Which .21 buggy engine to get for mbx5? please help rc_crazy22 Electric Off-Road 150 10-13-2003 06:45 PM
