Old 09-17-2010, 08:14 AM   #1
Default clutch bearings without grease in them
I use avid clutch bearings. They are packed with grease pretty good. Even if i blow the crap out of them with an air compressor, they still make my clutch slip when they are new. I have about 20 of these bearings and would like to know if anyone has a secret for dealing with the grease. Once they get some time on them they are fine but then i have to worry about bearing failure. Would it be a good idea to blast them with brake cleaner and put a drop of oil in them? Or would brake cleaner shorten the life of the bearing and cause a dnf?
ALso does anyone know who makes them without grease?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 09-17-2010, 08:23 AM   #2
JoeyTheRocket's Avatar
Send a message via AIM to JoeyTheRocket Send a message via Yahoo to JoeyTheRocket
I blast mine out with motor cleaner. Then leave them in Royal Purple over night (or a few nights). After soaking in the oil I mount them to a dremel and use a rang to catch anything that spits out. Once that's done I put them on my ride.
Joey Kubat ↔ MWNS Staff www.MidwestNitro.com
Mugen Seiki / AKA Racing / Novarossi / PT RC Racing Oils / Advantage Racing Products
JoeyTheRocket is offline   Reply With Quote
Old 09-17-2010, 08:33 AM   #3
cool thanks. all i have now is after run oil, air filter oil, and wd40. SHould i get something else?
Mugen
Old 09-17-2010, 08:38 AM   #4
Jaz240's Avatar
Trader Rating: 52 (100%+)
Go to walmart and get a few cans of non chlorinated brake cleaner. Its $2.50 a can. It won't hurt rubber or plastic. I go through 10 cans a month. I use it to clean out my shocks, my diffs, and spray out my bell and my flywheel
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 09-17-2010, 08:40 AM   #5
Integra's Avatar
a Proper bearing oil.
I use Road Lube from Boca and it works like a charm.
Old 09-17-2010, 09:32 AM   #6
Jaz240's Avatar
Acer Racing Sin Lube for me
Old 09-17-2010, 11:47 AM   #7
Davidka's Avatar
Trader Rating: 75 (100%+)
Marvel Mystery oil. They key is to not use too much of whatever you use so it doesn't contaminate the bell/shoes.
Old 09-17-2010, 11:53 AM   #8
Trader Rating: 21 (100%+)
^^^ MMO as well, been using it for a while.
Duster_360 is offline   Reply With Quote
Old 09-17-2010, 11:57 AM   #9
Tony Newland's Avatar
Trader Rating: 50 (100%+)
I've posted this somewhere else on rctech but have no idea where.. here's my routine:
2x fresh bearings: remove rubber seal and spray the inside bearing out with motor spray or nitro cleaner completely and run dry, replace seal. Outside bearing: untouched, doesnt matter if it slings some grease, it wont get inside your bell.
I'll run those through practice and quals then rotate the outter bearing inside the bell and put a new outside on before the main. Next race run as they are through practice and quals and rotate again before the main.
Doing this I havent had a clutch bearing failure in years and my clutch is the same everytime I hit the track.
Schumacher Factory Team - Core RC - Highest Servos - Avid - Lunsford - Bellgate Distributors - Jconcepts - www.Prime-hobby.com - IRCR
Tony Newland is offline   Reply With Quote
Old 09-17-2010, 02:55 PM   #10
merdith6's Avatar
Default Ha
I take a new set of bearings and simply put them in my clutchbell, and then install the clutchbell on my engine, install the engine, and then I start my buggy, and drive it for about 5-10 minutes in practice, and wow, it works perfectly for three race days or longer, never had any issues.
The oil flings out faster than the grease, so then you have a dry bearing hovering around 250 degrees with nothing in them. that's why most who remove the grease change them out every day or even before the main too. Not necessary, and wastefull...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 09-17-2010, 03:53 PM   #11
alexrckid's Avatar
BEST clutch bearings around.......check the video..
http://tkocompetitiondev.com/product...roducts_id=399
2008/2009 northeast super series Production MT champion
8T-2.0, werks B5, 2013, hitec's.
gallimods hobbies and raceway, barn/wolcott.
living in north myrtle beach. race at badlands
alexrckid is offline   Reply With Quote
Old 09-17-2010, 04:10 PM   #12
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
RPM makes a handy little tool for this very purpose.
http://www.amainhobbies.com/product_...earing-Blaster
Use some nitro spray or electric motor spray and give them a couple blasts each. Then follow that with a couple drops of a good bearing oil. I use some Racers Edge oil. Nothing fancy, just bearing oil but it works well.
As for TKO's I'll stick with my dollar bearings.
BTW I use metal shielded bearings. They last longer than any rubber sealed bearing I've tried in the clutch.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 09-17-2010, 04:14 PM   #13
jwm2's Avatar
Yeah no kidding i was looking for new bearings for my 8 buggy and checked on TKO cuz drake runs them. They sell a set for over $300, thats just insane. I'll stick with $1 acer bearings, they seem to work good enough for me. $24 for a complete set with free shipping and decals
8ight 2.0 - Go Engine 7 port | VP-Pro | Avid | Ace/XP 1015 & Hitec 5625MG
8ight-T 2.0 - Go Engine 3 port | VP-Pro | Avid | Ace/XP 1015 & 1313
Extreme-Mods.com - Xbox 360 & PS3 Mods, Parts, and Accessories
WillowBayNaturals.com - Handmade soap, lotions and body products made by my wife. Her lotions and soaps are flat out amazing. Give them a try, you won't be disappointed.
jwm2 is offline   Reply With Quote
Old 09-17-2010, 08:34 PM   #14
wfo
wfo's Avatar
slow down son ,those 300.00 bearings are for a full size car not R/c Tko sells bearings for .99 the best bearings i ever used when i ran a LOSI was tko (mr-695-rt) w/my Fioroni turbo-slider and those bearings i would never have clutch problems...
wfo is offline   Reply With Quote
Old 09-17-2010, 09:12 PM   #15
alexrckid's Avatar
yikes.....and, tko's got decals AND t-shirts............and not 300.00 smackero's........
Clutch Bearings hdcruzer Nitro Off-Road 33 04-29-2010 07:46 AM
Clutch Bell Bearings..... Your tips for longevity markhat250 Nitro Off-Road 61 03-19-2010 09:56 AM
Methods for cleaning/lubricating bearings? Chris__RC Nitro Off-Road 37 04-24-2009 07:35 PM
8ight clutch??? 1cougar1 Nitro Off-Road 28 01-21-2009 08:34 PM
Looking for the best clutchbell bearings, bar none! j_blaze14 Nitro Off-Road 38 01-19-2009 10:44 AM
