Old 09-17-2010, 05:16 AM   #31
jamiekerr14's Avatar
Autosol is a good one-Not tried it in piston mind you but works wonder's on my O.S. 2060 pipe.. makes it look brand new.. Im sure it would work on the piston head very well the more I think about it..
Xray XB4
Supported By:
RC Disco
jamiekerr14 is offline   Reply With Quote
Old 09-17-2010, 05:27 AM   #32
blis's Avatar
Default No bite, no chunk..
Originally Posted by 22Racer View Post
I would not touch it with anything that would round the corner or touch the sides. I use some 600-800 grid wet sandpaper on a surface plate with wd-40 and it cleans right up. When I resize a sleeve I always clean up the top of the piston, it does have some peformance gains.
Rex
yup similar..
I use the fine "wet and dry" (1000+), on a dead flat surface (glass). I then grab and old sleeve and wear the wet and dry down with an old used brass sleeve until it leaves a brass residue to act as a lube, sleeve head comes up a treat when you've worn off enough. You'll see etchings of the wetndry on the sleeve for a while and then the residue acts as a polish, keep going until it comes up nice!!
Then carefully and "squarely" polish in a figure of eight till just rid of the carbon deposit and done. Only the top of the piston, for the sides, whatever a soft wipe and metho wont remove leave.
And yes, dare I say.. dont go too hard and slip, chunking an edge, go real lightly as not to bite and let the piston glide freely. Just want to clean it after all. Can finish off with a polish if you like using a flat cloth but I find that after the wet'n'dry it's polished up too good to touch.
Also add, why'd we carbonize in the first place, look into plugs etc.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-17-2010, 12:28 PM   #33
22Racer's Avatar
Trader Rating: 67 (100%+)
Some people posted taking the rod off to clean the piston. I never take the piston off the rod unless I am changing the rod. It is just one more thing that can go wrong if you dont get the clips in right or lose one. These motors are very simple but it doesn't take much to mess them up, small piece of dirt etc.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 09-17-2010, 12:39 PM   #34
JUD
JUD's Avatar
Originally Posted by chicky03 View Post
You never want to clean the piston.
Maybe it's ok to clean the top of it but that's it. The carbon on the sides of the piston is from castor and it helps protect and gives the engine a good seal and lubrication. It's also best to leave the top all carboned up because then you can get a good read if the engine was running too lean if the carbon goes away by itself and there is pitting on the top.
Some fuel make the piston have gummy and sticky residue, That you want to clean off with a rag and some fuel but the piston should always be as black as you can get it.
WOW!! Very interesting.
JUD
Mugen Seiki - AB Mods - AIRTRONICS - Ninja - CR Graphics - Spektrum
JUD is offline   Reply With Quote
Old 09-17-2010, 02:28 PM   #35
helivaguy's Avatar
Trader Rating: 42 (100%+)
i always wash my engine parts and engine cases in my ultrasonic cleaner with a 50/50 mix of simple green and deionized water or distilled water.
remove that crap off the top and inside the piston otherwise it will come loose and redeposit inside the engine and through the bearings and could even foul out the glowplug,
engines should be clean inside as they are outside.
The only thing that is "still like new" is the box it came in..
Only a half gallon through it my Ass!
helivaguy is offline   Reply With Quote
Old 09-17-2010, 02:52 PM   #36
JayRC66's Avatar
I use brasso to clean the pistion head and rod. Then dip them in fuel for a bit. Then finish it off with denatured alcohol. Works fine for me. As for the casing I leave sitting in fuel for a while then wipe it down with a clean a clean rag.
Jovanny S.
Losi, Serpent, Schumacher, Ofna.... yea I got a little bit everything.
JayRC66 is offline   Reply With Quote
Old 09-17-2010, 02:58 PM   #37
Stanton's Avatar
Originally Posted by pitpop View Post
metal polish, and then clean it with motor spray... don't contaminate the side of the piston, especially around the top of the piston, it will screw up the seal between piston and sleeve... you have to be very careful doing this..
Mothers Aluminum Polish works awesome and I agree with not touching the sides and edges. Also works great on the button.
Good advise here from pitpop...
Horizon Hobby/Spektrum/Byrons/TLR/Houstons Engine Service
Stanton is offline   Reply With Quote
Old 09-17-2010, 03:01 PM   #38
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
A dremmel with plastic wire brush and some ARO will do the trick for the most part. If it is real thick, you may need to start with a brass wire brush.
As for cleaning vs. not cleaning, I always clean my pistons up periodically. I like a clean engine, and have been pretty lucky with engine life so I will continue to do so. Only clean the top, not the sides. If you don't clean the piston up you'll eventually get a thick enough coat of carbon(especially if you're using fuels with stupid dyes in them) that it can cause some issues.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 09-17-2010, 03:20 PM   #39
Stanton's Avatar
I have been told by some that the carbon can actually glow and cause pre-detonation. Since that makes sense, I've always kept the piston top and button polished
Old 09-17-2010, 03:27 PM   #40
Stanton's Avatar
I was on this program until I found out that ultrasound will destroy bearings and will cause pitting in aluminum. It does make them nice and clean though...
Old 09-17-2010, 03:36 PM   #41
The reason the carbon build-up can cause pre-detonation is because it effectively lowers head clearance and increases compression. Too little head clearance is what will cause pre-detonation.
-Koby Kubrin-
Old 09-17-2010, 03:41 PM   #42
Stanton's Avatar
Interesting...thanks for the info.
Old 09-17-2010, 03:44 PM   #43
22Racer's Avatar
How do use a dremel and not round the corner of the piston?
Rex
Old 09-17-2010, 03:46 PM   #44
helivaguy's Avatar
ultrasound?
false..ultrasonic cleaning does not pit aluminum nor does it pit any type of ferris or non ferris metal..dont know who sold you on that?
second only an idiot would sonicate an engine with the bearings in it.
Old 09-17-2010, 03:47 PM   #45
Rex
I'm only using a plastic wire brush and that ain't rounding off your piston.
-Koby Kubrin-
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
how long can a nitro engine last?? dreaux Nitro Off-Road 12 03-25-2009 10:33 AM
New to electric touring ... TC4 + brushless ... tips ? Tabushi Electric On-Road 9 07-22-2008 08:22 PM
Best way to clean my savage onintks Monster Trucks 10 03-01-2006 06:35 AM
Flushing a Motor TRAJ Onroad Nitro Engine Zone 30 06-09-2005 12:28 PM
